400 vs. 460
Old Dec 16, 2009 | 06:29 PM
chilsam's Avatar
chilsam
family
Originally Posted by fordtech08
sorry it's just one of my pet peeves when someone calls it a 351m/400 they don't call it a 429/460
I guess 335 family & 385 family is the proper quote but 335 also includes 351c which deck height is 1.09" shorter 351m/400 main journel dia,center to center on con rods,BH bolt pattern is diff also except on 73 full size 400 with fmx trans {codePHB-AB} same as 351c.
Old Dec 16, 2009 | 06:36 PM
paulq's Avatar
paulq
While we are on this subject can someone tell me if I have a 351m and wanted to change it to a windsor or cleveland what would need to be changed to to this?
Thanks Paul
fordtech08's Avatar
fordtech08
because the 400 was ignored by ford when it came to preformance it never came with a 4bbl, due to emissions they retarded the timing and then got rid of it before making it fuel injected,
Old Dec 16, 2009 | 06:39 PM
fordtech08's Avatar
fordtech08
Thanks Paul
a 351m is a cleveland essentially it's the same family 335 but it has a taller deck and shares a big block bell housing
so you would need a transmission or bell housing and mounts
also you would need new brackets for the add ons ps and alt
if you went with a windsor you'd need a fuel pump and distributor
Old Dec 16, 2009 | 06:40 PM
chilsam's Avatar
chilsam
I think more cubes to start with factory perf parts 429-460. Only four barrel intake,after market & after market cams,valve train gear 351m-400.
Old Dec 16, 2009 | 07:13 PM
Danny Stroup's Avatar
Danny Stroup
Originally Posted by SNSTER
so why is the consensus that the 460 is so much better then the 400?
I have a 400 too and am looking at keeping it. I want to do a "beefy OEM" type rebuild keeping the block, heads, & crank.
I've been reading alot of books and websites that basically say the 351M/400 "poo-poo" reported by many is a myth. I bought a book called "How to Build Max Performance Ford V-8s on a Budget" and it says the 400, when built right, will be plenty of motor w/great low-end torque, street performance, daily driving, etc.
No, we won't beat a muscle car on the drag strip, but it'll have plenty of attitude. The key, according to this book, is building the bottom end. You should check it out.
If I was going to be pulling a 5th wheel, horses, or cattle? I'd probably swap to the 460, add a tranny cooler, and maybe a new rear end.
Old Dec 16, 2009 | 07:21 PM
278broncos's Avatar
278broncos
SNSTER - I can't offer any first hand experience on a direct comparison between 400's and 460's - yet. What I can tell you from first hand experience is the 400 is plenty capable of satisfying your need for power.
I built a 400 about 5 years ago for my '78 Bronco to replace the tired 351. As usual, my "I'm just gonna rebuild it, baby - I promise" turned into much more. Massaged the heads a little by opening up the exhaust ports and gasket matching the intake side, had Comp grind a roller cam with their shortest duration intake lobe and next higher exhaust lobe, 9:1 pistons after boring it .040" over, Scorpion roller rockers, Edelbrock dual plane intake off of eBay, 600 cfm Edelbrock carb and small tube headers.
I couldn't have been more pleased. RIDICULOUS torque right off idle through about 4,500 rpm. Throttle so touchy that people don't want to drive it a second time. That was with 3:50 gears and 36" Swampers. I swapped those out for 4:56's last fall and we won't even go there.
Bottom line - the 400 is a fine engine and has the stroke needed to make awesome torque. I have buddies that swear by the 460. I don't think you could go wrong with either choice
Old Dec 16, 2009 | 07:26 PM
SNSTER's Avatar
SNSTER
Awesome. since my whole build is apparently going to be dare to be different I think it may be beefy 400 time
Old Dec 16, 2009 | 07:31 PM
fordtech08's Avatar
fordtech08
good choice I loved mine, I'm looking for one to replace my 351m in my 79 f150 now
Old Dec 16, 2009 | 08:15 PM
kentuckycrew's Avatar
kentuckycrew
The windsor flywheel and bellhousing are also diferent.
Old Dec 16, 2009 | 08:18 PM
fordtech08's Avatar
fordtech08
sorry I meant to say in addition to the rest you would also need the other stuff for a windsor
Old Dec 16, 2009 | 08:37 PM
smokeyb97's Avatar
smokeyb97
Originally Posted by Blown 331
I can't stress this enough. Swap to a 460 and never look back.
Also are some of you saying boring a 351m .030 makes it a 408? Wow, more like a 357. Thats rediculous.
I guess I assumed everyone would know that to get 408ci out of my 351M that I used a 400 crank with the TMI pistons that I mentioned.
Sorry for the confusion.
Old Dec 16, 2009 | 09:05 PM
  #28
RA051126's Avatar
RA051126
Banned
Your full of ****.....400 horse my ***.........
Old Dec 16, 2009 | 09:12 PM
  #29
thekingofcows's Avatar
thekingofcows
Here is what I know from my limited experience. My 79 Originally had a 400. It was completely stock and I ran the fire out of it. The right deal came along and I bought a 460. I traded off the old 400 and bolted in the 460. The 460 is fairly built; however, it does not genereate the low end grunt like the stock 400 did. But , while the 400 wound out at a relatively low rpm, you better get out of the 460s way when it gets to revving. I saw no gas mileage difference between the two. In my opinion, the 400 is the better motor if your truck is going to see stock gear ratios and large tires, the 460 at least in my case required me to regear to really get the motor in its power band, they are both great motors and are easy to swap. Just depends on your application i suppose.
Old Dec 16, 2009 | 10:50 PM
  #30
chilsam's Avatar
chilsam
Thumbs up ford
I think this site rules all these opinions are great! One thing we can ALL agree on is bow tie sucks hind t*t!!!
