Additives in our engine oil
Old Dec 16, 2009 | 10:19 AM
00Dave's Avatar
00Dave
Rich, is that boron or moron levels that are increased?
Old Dec 16, 2009 | 10:26 AM
white Buffalo's Avatar
white Buffalo
Good point! I think it could be a bit of each....
Old Dec 16, 2009 | 02:08 PM
stormyrider's Avatar
stormyrider
Motor oil manufacturers select the additive package based upon the oil base and what SAE spec they are making the oil to meet. Not all additives are compatiable with each other or some oil bases. Some additives like The teflon based ones can destroy an engine if it overheats as it turns the teflon into an acid that attacks bearings and gaskets. Others like dow cornings type M are mineral based(molybendumdisulfide) and are not compaiable with soft metals like those used in bushings and babitted bearings but work great on steel bearings like roller bearings or ball bearings. I would be very careful adding something to an engine oil without knowing what the downside could be and some of these outfits that market this stuff I wouldn't expect would stand behind it if an engine failure occured.
Old Dec 16, 2009 | 02:32 PM
big poppa's Avatar
big poppa
Hey Alvin, do you have a link to where all this talk and flaming is going on with this product, just want to see, curiousity got me...
Old Dec 16, 2009 | 04:43 PM
binuya's Avatar
binuya
Here Mike, try this. Not sure if it works.
I give you the Green Monster - Topic Powered by Social Strata
Old Dec 16, 2009 | 05:30 PM
tdpower's Avatar
tdpower
That's funny he is going to put that stuff in his tranny too!
Old Dec 16, 2009 | 05:34 PM
big poppa's Avatar
big poppa
Wow Alvin, got pretty hostile there for a bit. The guy knows his stuff . I don't think the fella is going to listen to reason, its a shame that nice truck is going to pay the price, o well, you tried..
Old Dec 16, 2009 | 08:25 PM
jrciii56's Avatar
jrciii56
Mineral Based = Molybdenum disulfide. You need to check you info on that one. Molybdenum is compatible with most every type of bearings. When moly was first used as an additive in the early 70's the type and concentration was over 2000ppm. It is very corrosive at that level. This is not the same as what is being used today.
Old Dec 16, 2009 | 08:27 PM
jrciii56's Avatar
jrciii56
Post that trucks serial number, so that none of us make the mistake of buying that truck.
Old Dec 16, 2009 | 08:52 PM
big poppa's Avatar
big poppa
Isn't that the truth. One born everyday Jamie, just wished he was driving a Chevy and not the Ford
Old Dec 16, 2009 | 09:06 PM
binuya's Avatar
binuya
Excellent idea.
Old Dec 16, 2009 | 11:11 PM
Visseroth's Avatar
Visseroth
Tell him DIESEL OIL ONLY! and that the higher the detergent the better. For some reason diesels like high detergents.
BTW, I didn't read all the posts :-P
Old Dec 17, 2009 | 07:37 AM
  #28
HD Rider's Avatar
HD Rider
Sometimes an additive comes along that does what it claims to do, Diesel Kleen for example. Motorsilk mentioned a 4-ball wear test but nowhere do they say what the results were. I would bet that is because the average synthetic oil would out perform it by a lot. They do show the pin on disc test results but I can't think of how that test might simulate conditions in an engine. I have never seen anyone else use that test method, but then I'm just a truck driver.
After reading all their test results and claims all I can say is Snakeoil.
Old Dec 17, 2009 | 09:41 AM
  #29
stormyrider
According to the dow corning rep(corning makes this as a type M additive) at a Detriot ball bearing seminar I attended the molybendumdisulfide is in a solution of 30 weight oil and they would not recommend it's mixing with synthetic oils. The also stated that because of its properties it works well with steel bearings but use around bronze, or brass bushings and babbited bearings should be avoided as itr would shorten the life expectency. It coats steel bearings and makes them slicker but will actually wear faster on softer metals like the bronze bushings.
97f250 7.3 4x4
13
Feb 10, 2015 07:34 PM
Mr.Dilac7.3
Jan 4, 2014 09:42 PM
RobertJohn
Mar 12, 2010 08:46 PM
ALL BOY
Dec 4, 2005 11:41 PM
ctsoth
Jun 8, 2003 10:30 AM
