Won't Idle
Old Dec 15, 2009 | 03:51 PM
coolguy1419's Avatar
coolguy1419
Won't Idle
I've got a 300 with a offy dual port intake with a quadra jet carb on it. I can't get the thing to idle or when I get it to idle it is at about 1400rpms. I've checked all my vac lines and put hose clamps on them to be sure. The motor runs good but just wont idle. It will idle for a few seconds then just die, it acts like it is starved for fuel. The carb is a reman. I've adjusted everything according to what everyone says. Back the screws out 1-1/2 to 2 turns and adjust the linkage screw. Anyone got any suggestions or ideas on what to do and try? Any help appreciated!
Old Dec 15, 2009 | 05:38 PM
Harte3's Avatar
Harte3
Vacuum leak some place? And switch ports that you connect your dizzy to and see if that makes a difference.
Old Dec 16, 2009 | 01:26 PM
coolguy1419
I found what it was. The intake was sucking air through a bolt hole that wasn't used and one was sucking air wasn't seated good. How tight are those bolts supposed to be?
Old Dec 16, 2009 | 02:00 PM
91Bronc300's Avatar
91Bronc300
80 or 90 inch pounds would be my guess for an aluminum intake. Try a dab of locktite.
wyckedcombo17
Aug 15, 2014 06:25 AM
Tuttle69
21
May 23, 2014 11:01 AM
Sprintcar
Mar 23, 2011 03:45 PM
Beats Me
May 12, 2004 07:37 AM
lilpig88
Feb 4, 2004 11:51 PM
