Strange Idle Issue, 1992 5.8 F250 85k miles
Problem getting worse and worse.
Idle surges up and down, about 70% of the time when the engine is warm. Sometimes it goes away completely. Please read all of the below points.
The Battery Gauge is very low without starting the car. It DOES start, even in 10 degree temps, so I dont think the battery is shot. The alternator charges when I hit the gas very quickly and efficiently.
The idle gets better when I put MORE draw (heat, more lights, etc.) on the electrical system, curiously, but it idles VERY low. (But the sturging stops or gets 80% better most of the time).
Now when I START the truck, i often hear an awful noise through the CD player, mid-low pitched noise for 3-5 seconds.
Also, my headlights are HID's,.. but when the truck is off they don't get enough power at the headlight plugs to power up. If I turn the car off while they are on (and only drawing 30 watts), they cut out within 10 seconds.
I am beginning to think this is a ground issue.
Also, my belt is squeaking, but seems tight. Could the belt also contribute to this?
The Idle surging has been steady through the following repairs:
IAC Valve, MAP Sensor, Vacuum Leak Repair, Sea Foam through Gas tank, New Battery terminals,FULL tune-up (Plugs, Wires, Distributor cap and rotor, Gas Filter, etc.), Reset computer properly, checked for unplugged items.
Car idles WORSE as it warms up, typically it runs fine upon first fire-up (when idle is high of course, it's getting more gas) But recently it's been getting worse, quicker.
I was told one of my plugs may be arching (but this guy is an idiot, and i just replaced them?) Not sure how reliable this is.
Yesterday the bat gauge waved up and down a bit, and the lights on my CD player pulsed a bit as well. Any suggestions?
The car has TONS of pick up, engine is responsive, and not sluggish.. except at idle.
I want to rule out inexpensive fixes before I waste time with the TPS sensor (since this is NOT a common issue with the 351 windsor from what I've read)
Can anyone offer any help? Nobody has a code reader for this vehicle and I'm a broke college student now, I can't afford to pay 100 just to have a code read, that's ridiculous. Please help.
You don`t need a code reader or $100 to pull the codes. Go to fordfuelinjection.com and from the list on the right click on self test.
I would do that first. I would then check that the battery connections are clean and tight. Check that the wires at the fender mounted starter relay are tight, check that the ground wire to the engine is tight and check all the heavy gauge wires at the ends for burnt/corroded wires.
Do not disconnect the battery to clean the terminals until you have pulled the codes.
Might be a good idea to put a volt meter across the battery with engine off (should read above 12.5v) and then again with engine running (should read around 13v).
improvement54
03-17-2015 08:15 PM
e1p1
50
03-27-2011 10:55 PM
