Exhaust
Old Dec 14, 2009 | 11:17 PM
dirtmonkey11's Avatar
dirtmonkey11
Exhaust
I am installing a new exhaust on my truck and was wondering what anybody thinks about true dual straight pipes. My friend’s truck has them and it sounds really good, currently my truck is being dumped right where the cat back connects after the y pipe. I want a more glass pack sort of sound, right now it just sounds like a chambered muffler, which I don't prefer but it does sound ok. My main question is there any things I should look out for when doing the install, and has anyone done this setup. The only thing I am worried about is the clearance around the pipes and which is the best way to route them. I am not sure if I am going to dump them right before the rear axel or bring them all the way back but either way the front of the exhaust will be the same. I am going to run two separate pipes off of each cat on each manifold and then run the exhaust from there, eliminating the y pipe.
The vehicle is a 2000 Expedition 5.4 4x4.
Old Dec 15, 2009 | 05:02 PM
Big Greenie's Avatar
Big Greenie
Temporarily Deactivated
The fuel tank is definately in the way. I remain utterly fascinated by the desire for "true duals" on this site. There is absolutely nothing to gain by doing this except draining you wallet. Oh wait...you get to tell your buddies you have "true duals". That has to be worth a grand out of pocket.
I would say that not running pipes out from under the body on an SUV like the Expy is a very bad idea. Maybe this desire for "true duals" is the result of CO poisoning from "dumping" the exhaust under the body
Just put a glasspack on it, another Y pipe, run duals out the back and call it good. Much cheaper, exact same results.
Old Dec 15, 2009 | 07:51 PM
ArgoExpedition's Avatar
ArgoExpedition
Now although I agree with Big Greenie.
I dont exactly agree with his delivery.
these rigs are big heavy boats and you want to maximize torque, and to do this it would be more beneficial to get high flow cats, Y into a larger single pipe, and adding a good high flow muffler like a flowmaster.
Since more than likely you will use it mostly on the street, I think a 2.5 inch or 3 inch single would be more than enough flow for that motor.
Obviously its up to you, and your pocket book, but upgrading the exhaust is not as beneficial unless you include other mods to take advantage of the increased flow.
Steve
Old Dec 16, 2009 | 08:38 AM
Big Greenie
Steve
Just call me Big Meanie
Old Dec 16, 2009 | 09:39 AM
dirtmonkey11
Thanks for the input, I am now going to just run a single outlet exhaust in the factory spot, As Big Greenie said it wouldn't be worth it, I have to agree I just thought at first that true duals would be a good idea but it isn't worth the time or money.
Old Dec 16, 2009 | 03:38 PM
fordtech08's Avatar
fordtech08
true duals on the mod motors also gives you a loss of power it's just the way the truck motors were built I agree just go with the single pipe into two
Old Dec 16, 2009 | 05:02 PM
Big Greenie
I would bet that if you went with long tube headers, an X-pipe and duals you could see some benefits. There isn't really room for this on these trucks and the cost to see a gain would be waaaaay out of whack.
The tube size back to the Y is actually pretty generous on my 5.4's. The cork is the factory muffler. Just remove that cork and replace it with your noisemaker of choice. I love the sound of my Magnaflow muffler.
Old Dec 19, 2009 | 05:19 PM
xpedition's Avatar
xpedition
Question
I have a couple of exhausting questions for the experts out there:
  1. Can a replacement tailpipe for a 4.6L 2002 Expy (no resonator) be used to replace the tailpipe on a 5.4L version (w/resonator)?
  2. If so, would there be any advantage, other than lower cost if the OEM item is damaged and needs to be replaced? i.e., will eliminating the resonator reduce back pressure, provide a "healthier" sound, or any other benefit besides improved visual appearance?
Just curious...
Old Dec 19, 2009 | 08:49 PM
1whoseeks's Avatar
1whoseeks
I am not an expert however this may answer your question about the resonator. The exhaust pipes in automobile exhaust systems are designed with acoustic resonators that work with the muffler to reduce noise, by making sound waves cancel each other out. Manufacturers use the resonator to enhance the sound. In tuned exhaust systems designed for performance the resonance of the exhaust pipes is also used to 'pull' the combustion products out of the combustion chamber quicker. Personally if i could i would leave the resonator and replace the muffler with an aftermarket one that has the sound your looking for. Resonators and cats have little resistance now a days. Fords have some of the most restrictive mufflers.
Imca00
Apr 17, 2014 04:42 PM
FordYoungGun35
Dec 10, 2012 01:24 PM
MichiganHunter
2004 - 2008 F150
Jun 25, 2010 01:21 AM
GAV10
Modular V10 (6.8l)
23
Mar 17, 2003 09:58 PM
jwchatm
Aug 10, 2002 05:08 AM
