Garage & Workshop Tips & Ideas for the garage or workshop. No Truck Tech Discussion
syphon sandblaster?
Old Dec 14, 2009 | 08:37 PM
ford1puller's Avatar
ford1puller
syphon sandblaster?
bought a syphon sandblaster from sears. got everything setup with the sand and compressor the compresser is 150 psi so im pretty sure its enough. anyways it dosent work the sand comes out alittle dosent do much of anything on metal.
Old Dec 14, 2009 | 09:28 PM
muscletruck7379's Avatar
muscletruck7379
mine will spray sand clear down to 50 psi or so, what are you using for sand? it sounds like its plugged up. put the nozzle up against something (I use my leg, but do at your own risk) so when you pull the trigger it forces air down the siphon tube. usually clears out anything in there.
Old Dec 14, 2009 | 09:59 PM
ford1puller
its blasting sand or thats what it said on the bag. its not the black sand media. ill try that thanks. cuz when i tried to use it last i could feel alittle comeing out but when i took the hose off the sand fell out of the bottom of the gun
Old Dec 14, 2009 | 10:22 PM
70sfordguy's Avatar
70sfordguy
psi is not what you need its cfm (Volume of air)
do you know the size of your compressor?
make sure the compressor has enough cfm to supply the blaster.
Old Dec 20, 2009 | 10:44 PM
Aftrmidnite's Avatar
Aftrmidnite
Air supply needs to be short as possible, with big hose and you need to take your quick connects off, as they are to much restriction. The Steel blast nozzles wear pretty quickly. I haven't used mine in years, switched to power washer sand injector. If you are doing a car, or other big project, hire someone with a Soda Blaster.
40LUTZAG
1997 - 2003 F150
Nov 7, 2010 06:28 PM
young66
Oct 11, 2010 09:45 PM
Duke78
Paint & Bodywork
17
Jan 16, 2008 02:10 PM
zukezake
Paint & Bodywork
Nov 20, 2002 08:41 PM
ke6bnl
Paint & Bodywork
Sep 22, 2000 12:40 AM
