cold start idle problem
Old Dec 14, 2009 | 06:37 PM
madtom's Avatar
madtom
99 E350 7.3 PSD. It starts fine, but when temps are 35 and below as it's warming up it revs and hisses and revs and hisses and revs and hisses until the motor reaches operating temp. If you try to drive it before the temp gauge reaches operating temp, it drives the same way (revs and then when it hisses it loses power, then it revs and when it hisses it loses power). I took of the cowel and it sounds like the hissing is coming from under the turbo. I can see an arm of some type that moves with the revving and the hissing. What is the problem?
Old Dec 14, 2009 | 06:42 PM
tdpower's Avatar
tdpower
I think a cat got stuck in your exhaust...lol.....No that is normal when cold the ebpv closes most of the way to help warm up the truck faster. This is the flap on the exhaust side of the turbo to the down pipe. Also, I think it is trying to high idle which is normal. If you press on the break the high idle should go back down.
Old Dec 14, 2009 | 06:56 PM
Ponyboychris's Avatar
Ponyboychris
Does your RPM's fluctuate as well when it idles? My old '99 PSD did that and I cleaned my EBPS and it went away.
Welcome to guzzle's Exhaust Backpressure Sensor Cleaning Maintenance Web Page
Old Dec 14, 2009 | 07:05 PM
madtom's Avatar
madtom
Chris: The RPM's do fluctuate.
Grant: If I touch the brake pedal, even with just my finger, it returns to a smooth idle for a short time and then continues to fluctuate again until warm.
Does that sound right?
Old Dec 14, 2009 | 07:10 PM
tdpower's Avatar
tdpower
It should go back up after you touched the brake but probably not right away. You rpm's should be pretty constant in high idle. Might try what Chris suggested and see if that helps.
DidieX
Aug 24, 2015 05:27 AM
Northstar55
Apr 20, 2015 09:16 PM
Determined99F350
15
Jan 7, 2015 10:52 AM
PigDiesel9
32
Nov 18, 2014 05:33 PM
datchew
22
Apr 19, 2005 09:14 AM
