Glow Plug Wire Harness
Old Dec 15, 2009 | 08:20 PM
Dave Sponaugle's Avatar
Dave Sponaugle
I did not get just the glow plug harness, I got the entire engine harness.
Old Dec 15, 2009 | 08:22 PM
Old Whitey's Avatar
Old Whitey
Guys, thanks for all the help. The bullet connectors from Radio Shack worked well.
I have one more question. I believe the glow plug relay is located on the right front fender well next to the battery but, what is the relay that's located on top of the engine block with a Z shaped coil on it? Again this is on a 1987 F350 6.9L.
Old Dec 15, 2009 | 09:45 PM
Dave Sponaugle
Relay on the fender is the starter relay, mounted up on the metal fender right?
The relay on the engine is the glow plug relay/controller.
Old Dec 16, 2009 | 05:36 AM
9473's Avatar
9473
That's less than the junkyard wants for them now. I had a price of $250 for the GP harness a couple of years ago.
Old Dec 16, 2009 | 01:14 PM
Old Whitey's Avatar
Old Whitey
Glow plug relay
Dave,
Thanks for setting me straight; I had the two mixed up. Guess I should get a repair manual. Any idea on where I could acquire one?
Old Dec 16, 2009 | 08:20 PM
Kleenax's Avatar
Kleenax
Glow plug bullet connectors
Originally Posted by 9473
I see these guys carry the replacement bullet connectors:
<STYLE></STYLE>7.3 L Ford Diesel Fuel Injectors Fuel Pumps Accessories
I couldn't find them anywhere on that site, but I did find 3 different sizes here: Bullet Terminal Connectors
Does anyone know what size the glow plug connector is? Also, the site that I found above offers either Nylon, Vinyl, or heat-shrinkable insulation on the various sized connectors.
Old Dec 24, 2009 | 07:41 PM
gmc ford 250's Avatar
gmc ford 250
Thumbs up replace wiring harness
ebay has wiring harness replacments for about 180.00 'bullet type'
Old Dec 24, 2009 | 11:39 PM
newr's Avatar
newr
Bullet Connectors & Stuff
That connector is rated to 150deg. I wouldn't be satisfied with the life considering the amount of work involved to pull and replace the harness. I bougth one for my '88, I know they are different, from the local International Truck dealership. Set me back $90 and I had to do some work on it after I got it home, but the connectors are correct and I am certain that they will survive the heat better.
The thing that got me mad was that where the wires were crimped into the lug that mounts to the controller one side crimped down on the wire and the insulation but the other only cought the insulation. So my spiffy new $90 harness only worked on one side until I crimped a new lug connector on it. That cost me a second controller, now sitting on the shelf as a back up.
Ron
Old Dec 25, 2009 | 02:46 AM
gmc ford 250
glowplug wiring harness
on ebay in search box type in ford glowplug wiring harness in all cat.
Old Dec 30, 2009 | 09:54 PM
magusjinx's Avatar
magusjinx
Originally Posted by Old Whitey
Dave,
I use Haynes #10330 "Diesel Engine Repair" and #36058 "Ford Pickups And Broncos '80 thru '96" from (cough) NAPA (cough) ...
mrbingsex
Dec 7, 2016 04:52 PM
justaworktruck
Oct 14, 2016 04:20 PM
Resendiz
Nov 12, 2015 06:58 AM
MustangMatt96GT
27
Sep 26, 2009 07:34 PM
cdv10
Jun 18, 2009 09:40 PM
