'01 Exp 5.4 won't start - Help
Old Dec 13, 2009 | 10:26 PM
80s Trucker's Avatar
80s Trucker
I recently pruchased a '01 Exp with a 5.4 litre engine with 60k miles. I took it to the the do it yourself car wash and when I went to start it, it would turn over and did not start. Had to tow it home. I am familiar with 70s ignition systems (DSII) but I don't even know what this is.
Does anyone know what Ford calls this ignition system used on this year of vehicle.l. Also any suggestions on where to start to check troubleshoot?
Thank You.
Old Dec 14, 2009 | 09:03 PM
Franklin2's Avatar
Franklin2
You probably have coil-on-plug ignition. The first thing to check is the codes in the computer.
Old Dec 14, 2009 | 09:32 PM
80s Trucker
Thank You. I will get a hold of a scanner. Any recommended ones to use?
Thanks
Old Dec 15, 2009 | 11:04 PM
Franklin2's Avatar
Franklin2
A simple OBDII should be all you need, nothing fancy. If you could get it to one of the auto stores, they could check the codes for you.
98expeditionXLT
23
Aug 1, 2015 09:27 AM
80s Trucker
Electrical Systems/Wiring
Dec 19, 2009 08:16 AM
Ken J
Oct 20, 2005 04:01 PM
Ford5.4L
Mar 14, 2005 06:11 PM
crp2000eb5.4
Feb 27, 2004 04:16 PM
