pitman arm ?
Old Dec 13, 2009 | 09:52 PM
BigJake34452's Avatar
BigJake34452
pitman arm ?
hey guys/gals i am in the middle of a 4x4 conversion on my truck, i got the front end in but i had to use the stock 2wd pitman arm and it drops down too low and hit a bolt (i cut off a little of the bolt so it would clear for now) but it seems like the 2wd's had a 32 spline pitman arm and the 4wd's had a 36 spline am i correct on this? if so anyone know of a place i can see about getting a 32 spline arm that will work for me? thanks.
Old Dec 13, 2009 | 11:03 PM
tnardo's Avatar
tnardo
i'm not sure if it matter 2wd or 4wd, it might just be factory or manufacture date, either way. as far as i recall you local parts store should be able to get you what you need
Old Dec 13, 2009 | 11:04 PM
tnardo's Avatar
tnardo
if not, look into a redhead steering gear, it's nice!
sgrol
28
Nov 30, 2019 07:39 AM
ashleyroachclip
WTB - Parts & other
Aug 18, 2014 06:08 AM
sammie0126
Nov 4, 2012 04:29 PM
PatsPOS
Sep 29, 2012 09:18 PM
diesel-fitter-bum01
Mar 20, 2012 08:12 PM
