RELOCATING THE BATTERY
Old Dec 13, 2009 | 07:50 PM
HD74's Avatar
HD74
RELOCATING THE BATTERY, so howed you do it and what type of battery box did you use and were did you relocate it? Pictures please!
Old Dec 13, 2009 | 08:09 PM
Old F1's Avatar
Old F1
Not mine……………………someone on this site, sorry old dead brain cells.
This is where I’m going to put mine, or if not enough room, between the bucket seats in a centre consol.
Old Dec 13, 2009 | 08:41 PM
jniolon's Avatar
jniolon
old and in the way
not done yet... but will reside in a homebuilt drop down battery box under the right side behind the running boards...like the drop down boxes you see in the magazines...
later
John
Old Dec 13, 2009 | 08:47 PM
Julies Cool F1's Avatar
Julies Cool F1
Mine is strapped into a HEAVY metal tray with supports high up on the passenger side firewall above the starter solenoid!
Name:  IE Sept 20  Engine Compartment Front.jpg
Name:  New Engine Installation Feb 11, 2007 3.jpg
Name:  J16 Right Lower Cowl Repair.jpg
Wow my cab look so much better now! Note the ground disconnect shunt switch....really comes in handy for working on things.
Old Dec 13, 2009 | 09:04 PM
AXracer's Avatar
AXracer
Personally I would not put a standard lead acid battery inside the passenger compartment or that close to electronics/electrical center. Lead acids still vent acid fumes and hydrogen gas. If you want to do so, I would used a sealed gel cell "any position" battery such as an Optima. Optima makes a 6V version that is 1/2 one of their "6 pack" (a 3 pack?) configuration. 2 of them can be run in series to give 12V in an arrangement that can fit easily behind a seat or even lying on their sides under the seats. That's what I plan on using in my panel, standing side by side located in one of the covered compartments along the wall behind the seats.
Old Dec 13, 2009 | 09:15 PM
B/B ford's Avatar
B/B ford
Clean & Classy
Mine is the stock location in a new drop down box.(stainless) and it is accessible through the floor cover by lifting back the carpet. I also use an Öptima battery.
Old Dec 13, 2009 | 09:33 PM
HILLBILLY BOB's Avatar
HILLBILLY BOB
Hey Julie is that a moonshine jar on the firewall?
Old Dec 13, 2009 | 09:56 PM
AXracer's Avatar
AXracer
Julie, ground switch is a good idea, but I don't see any clamps holding the battery in place in the tray?
Old Dec 13, 2009 | 10:49 PM
dongc1's Avatar
dongc1
I used a Exide Orbital (sealed like a Optima) behind the seat in my 49. Made a black plastic cover over it. Looks good and worked out great.
Old Dec 13, 2009 | 10:55 PM
51PanelMan's Avatar
51PanelMan
It's a windshield washer bottle.
Old Dec 14, 2009 | 02:39 AM
Julies Cool F1
Not at the moment, but I'm always willing to accomodate a good idea!
I was working on the firewall and cowl paint and had the battery out. I had set it back in but not engaged the strap when I took the pictures - it is a single strap and runs from firewall to the front of the box. The battery is actually very close to the lip on the top of the cowl and requires a little gentle maneuvering to get it in and out even without the strap tight fit.
Yeah, but Ilya...now Hillbilly may have a good idea, lets not be hasty!
I wonder of moonshine would clean the windshield too?!
Old Dec 14, 2009 | 06:03 AM
norvillebob's Avatar
norvillebob
if it's worth a damn it'll take the paint of your truck too.
Old Dec 14, 2009 | 07:29 AM
49willard's Avatar
49willard
I don't have pictures however, on my 49 I located a SS dropdown box on the passenger side approximately underneath the seat. It is just forward of the center crossmember. Note that I moved the center crossmember back about 1 ft to accomodate the AOD trans. I am going for a "clean" engine compartment but retaining the stock fuel tank and did not want it in the bed-process of elimination.
Old Dec 14, 2009 | 08:16 AM
bobbytnm's Avatar
bobbytnm
Roast em' if you got 'em
On my 49 I recessed the battery down into the bed floor on the right front side. it basically sits on top of the extra flange on the running board.
Normally this would'nt let the batter sit down far enought and it would stick up through the bed floor, but since I'm using a bed floor from a 2005 GMC that is 2" higher than the stock bed floor its not a problem.
Here is pic of cutting the access door into the bed floor;
Bobby
Old Dec 14, 2009 | 09:37 PM
mytbtruck's Avatar
mytbtruck
This one is mine. I have a sealed top to cover it and it will be vented through the floor. I was going to put an Optima sealed battery in this place. I called Optima and they told me their batteries emit fumes when charging just like other batteries. I could not see paying extra money for the Optima. They are very good batteries and I have never heard any complaints.
