2150 2V Carb CFM???
Old May 14, 2000 | 06:17 AM
Bob_VT's Avatar
Bob_VT
2150 2V Carb CFM???
Does anyone know what the CFM rating a 2150 2 barrel carb have? Did Ford make a larger 2 barrel other than the standard 2150?
Old May 15, 2000 | 05:24 PM
PetesPonies's Avatar
PetesPonies
2150 2V Carb CFM???
Old May 17, 2000 | 12:55 PM
mk's Avatar
mk
2150 2V Carb CFM???
There are probably half a dozen different cfm ratings for the 2100 series carbs. On the left side of the float bowl there is a number, ie- 1.08, that indicates the diameter of the venturies. I believe the 1.08 is somewhere around 300 cfm.
Old Jul 29, 2024 | 10:11 AM
Yendra Built's Avatar
Yendra Built
I read somewhere that two barrel carbs are measured at a higher vacuum than a four barrel. I don't remember whether it was my Holley or Rochester book. Check on the Holley website it may give the cfm rating for a carb and at what pressure drop it is rated.
Old Jul 29, 2024 | 10:49 AM
5851a's Avatar
5851a
Think the biggest were used on the short lived 429 2V. 1.33 425cfm ? The original post is 24 years old.
68cabby
Apr 3, 2013 02:33 AM
MEPR
Mar 26, 2003 05:59 PM
gsc1996
Aug 28, 2002 06:42 AM
canadiangal
Apr 22, 2002 09:48 PM
