Replace sending units without dropping tanks
Old Jul 28, 2024 | 10:29 PM
Dano76's Avatar
Dano76
Can I swap the sending units in my 79 f150 with dual tanks without dropping the tanks?
Old Jul 29, 2024 | 10:59 AM
jflem's Avatar
jflem
No sir. Unless you pull the bed.
Old Jul 29, 2024 | 11:14 AM
Dano76's Avatar
Dano76
Thanks, I thought that would be the answer, but I hoped not...! <grin>
Old Jul 29, 2024 | 01:40 PM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
X2 for sure NO on the rear tank, unless you have a 1" too 3 " body lift. Or like Jflem said pull the bed. Get under and look, you can not get to the lock ring to tap it loose. And I am sure the sending unit has to be rotated when put in and with the tank installed and the bed on no clearance at all.
And cutting a access panel in the bed is NOT a good idea either. Gas tank drop walk thru below.
https://www.ford-trucks.com/forums/1...l#post14696841
elkhart75839
19
May 8, 2024 07:29 PM
ericboj
Jun 2, 2014 11:51 AM
cato47
Mar 19, 2010 11:38 AM
