What do i need?
Old Dec 14, 2009 | 12:13 AM
mechelement's Avatar
mechelement
Originally Posted by Dave Sponaugle
No Dyoung14 posted a utube vid a while back of 4400 RPM shifts.
Then you could hear the lifters clacking in the video on the last run up to 4400.
Also heard "oh xxxx, what was that" in the backround as grey smoke was noticed in the exhaust.
I'm going to have to search for that. I was following his 4400RPM shift thread and never saw the video.
Edit: Found it.
Old Dec 14, 2009 | 04:43 AM
bigbraunboy's Avatar
bigbraunboy
lol crazyness
Old Dec 14, 2009 | 10:34 PM
dyoung14's Avatar
dyoung14
funny thing is tho, it hasnt done it since and i continue to run past 4000 alot
Old Dec 14, 2009 | 10:46 PM
mechelement
That thing is a beast. What have you done to the motor?
Old Dec 15, 2009 | 06:58 AM
dyoung14's Avatar
dyoung14
Not much right now, the reason im being so hard on this motor is to see what breaks and see what i need to upgrade so i can run this rpm and nothing happen, so far it looks like valve train needs some work, but the bottom end seems solid, only things i have done is Put brandnew injectors a rebuilt ip ram air intake 3 inch exhuast turned the pump up put a high rpm spring in it and stick my righ foot into it
Old Dec 15, 2009 | 06:12 PM
Dave Sponaugle's Avatar
Dave Sponaugle
You need 7.3 style rockers for sure.
Sad thing, the 86 is a good block to rebuild.
If you drop a valve head or bust a rocker, the block will probably crack and just be so much scrap metal.
Old Dec 15, 2009 | 10:06 PM
dyoung14's Avatar
dyoung14
I have a set of 7.3 style rockers setting here looking at me, tell me how to put them in and i will do it next chance i get
