RABS Light On
Old Dec 12, 2009 | 11:40 PM
Uncle Grumpy's Avatar
Uncle Grumpy
RABS Light On
Hi,
When I start my '91 f150 the RABS and brake light come sometimes after a few minutes of driving and sometimes even before taking off without touching the brake.
I have check fluid level all ok. I've changed the brake fluid and bleeded the entire system including the RABS valve using a power bleeder.
However the lights still come on. The RABS don't put any codes into the system do they? Any Ideas?
Old Dec 12, 2009 | 11:47 PM
Hitokori's Avatar
Hitokori
um try changing ur brakes they may be bad wore out.... mines on too but i think i just need new brakes
Old Dec 13, 2009 | 03:08 AM
Uncle Grumpy
I have already changed them.
Old Dec 13, 2009 | 04:14 AM
Lazy K's Avatar
Lazy K
The red and ABS lights on together is usually low fluid level (already checked), loose/dirty plug connections at the master cylinder or a faulty fluid level sensor.
If you look under the dash, probably around the parking brake pedal or maybe behind the glovebox you should find the RABS diagnostic plug connector. Probably a black wire with an orange stripe plugged into a black wire. With ABS light on if you momentarily ground the black/orange wire the light should start to flash single or two digit codes.
Old Dec 13, 2009 | 06:17 PM
Uncle Grumpy
Thanks Lazy K I'll have a look and see.
Old Dec 13, 2009 | 07:49 PM
Linemo's Avatar
Linemo
the sensor that reads the gear on the carrier that informs the computer is on top of the axle held in place by a bolt it unplugs and is quickly replaced!
