High torque starter
Old Dec 12, 2009 | 09:26 PM
MUSKRATT2's Avatar
MUSKRATT2
High torque starter
I have an 85 460 with the 85 starter on it. I want to put one of the newer model High torque starters on it. I know that on 5.0 liter engines you can put a newer high torque starters on an older model but you have to rewire some stuff. Can you do this with a 460 as well. What all do you have to do? What year starter do I have to have? Where can I find a wiring diagram to do this?
Old Dec 12, 2009 | 09:55 PM
85e150's Avatar
85e150
Google "high torque starter" and find:
Ford high torque gear reduction starter
and a host of others.
Should wire up just like your existing starter.
Old Dec 13, 2009 | 07:14 AM
MUSKRATT2's Avatar
MUSKRATT2
What you have here is aftermarket starters, isn't it? What I'm looking for is an OEM style starter. Didn't they make a High torque oem starter in the later models? The reason is I could get one a lot cheaper.
Old Dec 13, 2009 | 09:01 AM
monsterbaby's Avatar
monsterbaby
Yes they did. And yes you can. what you have to do is run your current starter wire down just like your current setup adn then you run a jumper wire from the big terminal that hooks into over to the S terminal on the solenoid on the high torque unit and your good to go.
Old Dec 13, 2009 | 09:27 AM
MUSKRATT2's Avatar
MUSKRATT2
What year starter do I need to get? Is this basically the same wiring setup as switching from the old style starter to a new style on a 302? What size wire do I need to use?
Old Dec 13, 2009 | 10:11 AM
Bear 45/70's Avatar
Bear 45/70
My question is "WHY?" I've had 12.5 to 1 compression motors and as long as the starter and battery were healthy and the cables were a heavy enough gauge, I never had a problem. So why would you need a high torque starter on a low compression motor?
Old Dec 13, 2009 | 10:22 AM
monsterbaby
Bear read post 3 he says he can get it cheaper. and they do work good.
Answer to your question muskrat 92 or later F350 with a 7.5 is your application to ask for.
Old Dec 13, 2009 | 10:54 AM
MUSKRATT2's Avatar
MUSKRATT2
[quote=monsterbaby;8235513]Bear read post 3 he says he can get it cheaper. and they do work good.
Your exactly right here monsterbaby! I've done this before on my 302 vehicles & it works great & saves your battery life as well! I guess the only question left here to answer is what size wire to make & where do I get a wiring diagram to do this because I lost the one that I had before to do it to a 302.
Old Dec 13, 2009 | 11:36 AM
monsterbaby
it doesn't take a large wire for the jumper. 12ga is overkill but what I usually use personally
bigb56
Jul 3, 2013 01:20 PM
Eco Taxi
Nov 8, 2012 10:19 AM
Rory_Johnson
18
Jan 22, 2011 04:53 PM
pipman76
May 4, 2008 08:29 PM
bb78bronco
Apr 16, 2001 09:53 AM
