hydro locked!!! help!!!
Old Dec 12, 2009 | 07:20 PM
btm991's Avatar
btm991
i was going through a puddle and after i got through it the engine died. then i barely got it restarted and it blew white smoke for about 5 min. i then drove it about 10-15 miles and it drove great. said i needed to check my filter so i got a new one. how will i know if my truck is hydro locked.
Old Dec 12, 2009 | 07:34 PM
guzzle92's Avatar
guzzle92
If it were hydro-locked, it would not turn over and you would probably have overstressed or bent a rod in the process.
Old Dec 12, 2009 | 08:10 PM
btm991's Avatar
btm991
so i would have already known
Old Dec 12, 2009 | 08:11 PM
btm991's Avatar
btm991
so i would have already known?
Old Dec 12, 2009 | 08:54 PM
74baja's Avatar
74baja
Yes. Hydrolocking occurs because liquids are not compressible. Therefore, as the piston rises in the cylinder, if there is any water, it will meet a point where the volume will not decrease anymore. This leads to broken internals, most likely a connecting rod. This has always been my understanding at least, I'm always open to correction.
Old Dec 12, 2009 | 09:01 PM
farmdad's Avatar
farmdad
Yep. What Bob said. If you hydro-locked the engine by driving through a puddle then you had to have an open shot up the air intake without a filter in the system. The filter would have difused the water so it wouldn't have gone straight into the engine. You may have saturated the filter enough to restrict air flow into the engine. That would have prevented the injected fuel from burning causing the white smoke and hard starting.
Old Dec 12, 2009 | 09:11 PM
btm991's Avatar
btm991
thanks for the replys
CHOPTASTIC93
1997 - 2003 F150
May 29, 2014 07:09 AM
rollinblackcloud
Offroad & 4x4
Mar 10, 2014 11:59 PM
tjustice
Nov 2, 2012 11:31 AM
abowman
Nov 1, 2012 10:02 PM
secakc
Feb 28, 2011 03:36 PM
