BW 13-45 Linkage
Old Dec 12, 2009 | 11:53 AM
jplinville's Avatar
jplinville
BW 13-45 Linkage
The PO replaced the transfer case before I bought the truck from him, but he neglected to replace the linkage. the Haynes manual does a poor job of not putting pictures in showing what this linkage looks like, as I could fab it up if I had pics.
Can someone post pics of the linkage, please.
Better yet...anyone have the linkage that they don't need? I'm willing to purchase it also, if the price isn't too high.
Old Dec 12, 2009 | 04:28 PM
jplinville's Avatar
jplinville
Bump
Still looking for help
Old Dec 15, 2009 | 09:38 PM
jplinville's Avatar
jplinville
Bumping again. Does anyone have pictures of this linkage? i'd really like to use the 4X4 soon, as we are in the season for heavy snow...
Old Dec 16, 2009 | 10:12 AM
jplinville's Avatar
jplinville
Wow...it's as if I have offending body odor here.
Old Dec 16, 2009 | 02:05 PM
F150xlt's Avatar
F150xlt
This picture shows the linkage from a BW1345 transfer case to a Mazda M5r2 transmission.
I don't know if the linkage to a ZF 5 speed is the same.
Below picture shows the transfer case shifter bracket.
The red arrow points to a u shape cut out in the bracket where the end of the rubber transfer
case vent hose is held in place.
This picture below shows the bracket that bolts to the transmission. Note the plate has a cut out pattern in it that a nub in the shifter follows. Also note the two red arrows show the two bolts that hold the bracket to the transmission.
This picture shows the two bolt holes in the transmission that the bracket bolts to.
Last picture shows an over all view of the linkage.
Old Dec 18, 2009 | 09:00 AM
jplinville's Avatar
jplinville
Thanks!! Now I'll search the box of parts that were found behind the seat after I bought it to see if it is in there.
Old Jan 15, 2010 | 01:14 AM
southernchaos's Avatar
southernchaos
have a question i have spent too much money swapping my truck over from 2wd to four wheel drive i have installed a 6 inch lift the chicken wing dana front axle 3inch blocks in the back with add a leafs the truck is a 1994 ford f150 4x2 sport is with m5r2 trans will a 4x4 tail housing and transfer case i bought used out of a 1993 f150 4x4 fit this truck or is the shafts inside a 2wd and 4wd m5r2 trans different please help me with this or direct me to somewhere on this site that can any help will be greatly appreciated
Old Jan 15, 2010 | 01:21 AM
9.ford.5's Avatar
9.ford.5
not sure about the M5OD for sure but i know the Zf 5-speed the housing and tail shaft need to be changed for sure...i think the M5OD requires this too...youd be better off looking for a ZF 5-speed thats already 4x4 much better tranny
Old Jan 15, 2010 | 01:42 AM
southernchaos
well my biggest issue is that i have pretty much ran outta money and patience on this truck is it that my main shaft is to long in my trans if so cant it theoritacally be ground down and tcase put it to get me buy for the mean time till funds permit otherwise? my spelling is horrible lol
Old Jan 27, 2010 | 09:43 PM
jplinville's Avatar
jplinville
**UPDATE**
I found the linkage cor the transfer case...it was under the seat!
Now...One of the plastic bushings (clips the linkage to the little pins) is pretty tore up. Where can I get my hands on another one without climbing under one in a pick n pull??
Old Jan 28, 2010 | 12:55 AM
Mr. Finch's Avatar
Mr. Finch
It is just a piece of rubber, take a piece about the same thickness, sut a ring around it so it will stay in place on the linkage, and then drill it out to match the other.
Or it is very easy to get one out of the bone-yard, they just Pop on and off. Make sure you grease it a little and clip it on all the way.
Old Jan 28, 2010 | 08:18 AM
jplinville's Avatar
jplinville
If I hadn't been laid off, I would have grabbed a piece at work and spun the needed piece on the lathe. My lathe and mill are in a garage in Ohio, and I'm stuck here n Utah.
Perhaps I'll take measurements and have my brother go to my garage and spin them up for me.
I didn't know if it's a part that I could find in a parts house...
rsh1966
Jul 20, 2017 04:28 PM
F22driver72
May 1, 2017 10:45 AM
Oldschool2888
WTB - Parts & other
Apr 21, 2016 07:06 PM
roadrash63
Mar 5, 2016 10:45 AM
Rogue_Wulff
Feb 5, 2011 07:33 PM
