Does anyone have this combination? An AOD trans with a dolphin electronic speedometer? If you do could you tell me how the sender is attached to the trans and pictures would be great. Thanks
I put a `91 lincoln aod transmission in my `56. I used the original sending unit that
was in the aod. I have a "Classic Instruments" electronic speedometer. When I hooked
them up and got the `56 running, the speedometer registered perfect. Did not have to make any adjustment. Your going to really like the aod. Hope this helps.
I`m running a `57 T Bird 312 Y-Block. A .305-1 9 inch rear end. 15 inch tires.
And turning about 1875 rpm at 70 mph on freeway. I`m way past burning tires in my old age and really enjoy cruising at this stage of my life. I very happy. Sorry I don`t have any
pic`s of the electronic sender but I don't really think you need one. It`s pretty
straight forward. Good luck with your build.
