Best guages?
Old Jul 1, 2002 | 11:12 AM
Ironwolf21's Avatar
Ironwolf21
Best guages?
Ok I switched from stock to a 302 and AOD now I need guages and instruments. Is Dolphin the best or VDO?
Also speedometer cables, is standard cable for my motor usable?
Old Jul 1, 2002 | 11:17 PM
55FordLover's Avatar
55FordLover
Best guages?
I have the same setup and went with stewart warner gauges. They have the tear-drop and come in black or white face with chrome bezels. The place I got mines is www.speedwaymotors.com The prices was even the cheapest I could find on the net - $223 bucks for a complete set. I am using only 5-gauge set. The 6-gauge set cost about $10-12 bucks more. Their people were very helpful with the everything I need to know about setting up the 302/AOD combo too. No extra crap needed to get the job done. I highly recommend going to them first before Summit, Jegs or any other place. Item was received like 2-3 days after I ordered. Well other than that good luck and happy hunting.
James
54 Ford F100 302/AOD
55 Ford F100 223/3spd (SOLD) :-)
Old Jul 3, 2002 | 08:57 AM
winfordr's Avatar
winfordr
Best guages?
I bought autometer gauges for my 54 because I wanted a tach, and it had to fit in the original space. So I had to built a custom gauge cluster. All the gauges are 2" except the speedo and tack, which are 3 1/8". Pics in my gallery.
Winford
Old Jul 3, 2002 | 11:39 PM
visalia6439's Avatar
visalia6439
Post Best guages?
I have the VDO "Cockpit Royale" in my '59 F-100. I am not overly thrilled with them. I'd go with the other two recommendations you received in reply's: either Stuart Warner or AutoMeter. If it didn't irk me so much to pay for gauges twice, I'd replace mine with either SW or AM.
Good luck with your project truck...
Daryl
Old Jul 3, 2002 | 11:42 PM
visalia6439
Best guages?
oh, regarding the speedo cable: for the price of a new speedo cable, I'd replace it to ensure it's compatible with the 302. ALSO, I had to change the speedo gear at the end of the speedo cable where it screws into the tranny. But, that "may" have been a function of the tires (255/70X15). Just thought I'd throw that extra tid-bit at ya, since it came up when I went through it on mine...
Later!
Daryl
Old Jul 4, 2002 | 06:26 AM
Caddy 53's Avatar
Caddy 53
Best guages?
Responce to #3 post.
I'm headed the same direction with VDO gauges in the plan along with tach. Going to use custom inst panel on my 53 adding the tach for total of 6 gauges. What is your complaint with VDO causing you to prefer the other brands? Also the Speedo is driven by Elec sensor mounted to tran.No Cable to fool with.
My complete plan is 5.0 EFI roller mtr W/ AOD tran from MK7 and Ron Francis Wiring. All the details not complete yet. May install mass air with more cam for some rock and rumble.
caddy 53 chuck
Old Jul 4, 2002 | 12:21 PM
truckfarmer's Avatar
truckfarmer
Post Best guages?
for a custom Billet dash, contact www.jbmicrofinish.com
Old Jul 4, 2002 | 02:27 PM
51f1's Avatar
51f1
Best guages?
Moon-Eyes
Old Jul 17, 2002 | 01:19 PM
koshare's Avatar
koshare
Best guages?
I'm also curious as to your complaint about the VDO gauges. I was considering SW wings or the VDO. What is your dislike about them. I bought one just to see how it would look in my dash, and really like the mounting sleeve. But needless to say that in itself is not enough reason to buy them.
Old Sep 22, 2002 | 09:04 PM
crowebar's Avatar
crowebar
Best guages?
Just installed VDO gauges in my 55. Had to change sender in tank that was provided and very simple with excellent instructions. Used electronic speedometer was a snap to set and like my gauges very much. Used a cast dash insert that fit with stocks holes. Looks good and works great.
Old Sep 24, 2002 | 03:05 PM
RCsanjose's Avatar
RCsanjose
Best guages?
just so you know Moon Eye guages are made by auto meter......
Old Sep 24, 2002 | 07:29 PM
Gwilkrrs's Avatar
Gwilkrrs
Best guages?
VRMTHNT
Sep 7, 2010 04:43 PM
fixitman1310
Nov 7, 2009 02:39 PM
Bookman
Nov 8, 2007 10:23 AM
hotshothauler
16
Nov 8, 2005 10:35 AM
brabe
Nov 25, 2003 06:42 PM
