Sponsored by: Auxito
A/C heater HELP
Old Dec 11, 2009 | 07:26 PM
teaff1979's Avatar
teaff1979
A/C heater HELP
I have a 98 f150 4x4 the ac was working fine during the day i used the heater that night and now the ac will not work. I can turn the control to the coldest seting and it will blow warm air and i turn it to hot it will burn u out. it will change from defrost, to pannel, and floor. But even on cold seting and max ac it blows warm air. on vent it does the same thing. please help.
Thanks
Old Dec 11, 2009 | 08:04 PM
steve(ill)'s Avatar
steve(ill)
look up "blend door". the hot air from the heater and cool air from outside are "blended" together to get the temp you want. the blend door is controlled by a small electric motor and a cam/ crank. the motor can burn out or the cam/ crank can break and the door will be stuck or flop around... the door and motor are above the trans hump, below the radio. take off the plastic below dash and look... listen.
