Another 4x4 question
Old Dec 11, 2009 | 03:09 PM
muddingmcdude's Avatar
muddingmcdude
well i guess i will just start off my 4x4 dont work i put brand new warn manual lockin hubs on. i lock them in turn the switch on all the u joints and drive shafts spin but will not grab the wheels? took them back apart today everything looks fine the only thing i can seee that not workin right would be the sleeve doesnt go far enough in to grab the axle shaft?? has any one have a problem putting warn hubs on there trucks ???? im so confused right now every one tells me that they have never had any problems
Old Dec 11, 2009 | 03:29 PM
PaysonPSD's Avatar
PaysonPSD
IIRC I beleive the Warn hubs need to turn almost 360° to lock. Can you turn the hub lock nearly 360°. If you can and still do not have enough travel to engage then you may not have the right hub kit.
Old Dec 11, 2009 | 07:45 PM
muddingmcdude
its like a 1/4 turn it says lock and when i pull it apart the spring that pushes on the sleeve moves all the way? every one i talk to says that its the right kit? im lost still it makes me mad i spend 200$ to get my 4x4 to work and it still dont arghhh
Old Dec 11, 2009 | 08:10 PM
zx250's Avatar
zx250
Of the next Riffraff East
If they are warn Premiums, you need to turn them almost a complete round like Robin said. Or as far as they will turn.
Old Dec 11, 2009 | 09:59 PM
PlatinumPete's Avatar
PlatinumPete
X3 what Robin and Barry said, technically it's 9/10ths of a turn but basically almost a full turn. If you got Premiums the correct part # is 38826.
