block numbers
Old Dec 11, 2009 | 01:11 PM
jerm111's Avatar
jerm111
Question block numbers
i just pulled my motor and was looking at the casting numbers and was trying to find out a little more about my motor.
i have these numbers, can anybody tell me what they mean?
behind the starter i found; D7TE A85 AND 7L29
HELP?
Old Dec 11, 2009 | 10:49 PM
steponit's Avatar
steponit
D7TE
D - 70's decade
7 -year of decade = 77
T - Truck
E- Engineering
6015 - Engine Block
AB5 - change up suffix
7L29 - cast on July 29 1977
The engine is a 400 as that was designed for the 77 Ford Truck
Old Dec 11, 2009 | 11:05 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Since the 351M/400 bare blocks were all cast as 351's, how can you determine from the casting number it's a 400?
You cannot. When finished, the block could be a 351M, or a 400.
Casting numbers are worthless in most cases for ID'ing what the engine size is.
The casting number should read D7TE-6015-AB2 not AB5 .. since the block was cast in 1977.
