Exhaust system
Old Dec 5, 2009 | 04:38 PM
Mike's 77's Avatar
Mike's 77
Exhaust system
So my truck is currently in the shop getting a new motor put in it along with an edelbrock intake and 4bl carb set up and I am considering doing headers on it as well as possibly a whole new exhaust setup. Anyone have any ideas or suggestions as far as what brand or style to go with. It has I believe either 2.5" or 2.75" pipes and dual flowmaster mufflers on it now with stock exhaust manifolds and sounds good and loud. But I'd like it to be a bit more loud and abnoxious. I was thinking Hooker Headers and glasspacks with 3" pipes. Any other suggestions?
Thanks,
Old Dec 5, 2009 | 06:55 PM
Sayer Lane's Avatar
Sayer Lane
My 76 With the 302 has full length header that are hedman headers. Hooker are better just didnt have the money. And i also have true duals not cat with 18" glasspacks that i busted while they were hot by shoving a water hose up the tail pipe. My buddy said he heard me from a mile away when i was gettin on the throttle one day. I like it but thats just me. Oh yeah the pipes are 2"
Old Dec 5, 2009 | 07:37 PM
ArcadeTom's Avatar
ArcadeTom
My '74 with 302, Holley 600 4 bbl and Edelbrock Performer exhales through Flo-Tech headers (with 1/4" mounting flange) and 2 1/4" duals and 3 chamber Flowmasters. It's not enormous loud, but sound great at idle and also when you romp on it.
My exhaust guy had tole me a small block doesn't need anything larger than 2 1/4, FWIW.
Old Dec 5, 2009 | 10:13 PM
Kennewick's Avatar
Kennewick
Any of the above but not 3" pipes. All the heat and velocity will be gone and the moisture will all condense out of the exhaust gasses in your pipe.
My opinion..... 2 1/4 to 2.5" bullets 2 1/4 tail in front of the rear tire. An H pipe will balance the sound between sides. It may drone you right out of the cab but if you fatten up you idle a half turn or so you will get that drone toned down while your at stop signs. It will be lean and will need a bit of fuel.
Old Dec 5, 2009 | 11:05 PM
Q's 86's Avatar
Q's 86
youre not just doin this to keep up with me are ya?? whos copyin who now? haha and im doin hooker headers and flowmaster delta 10 series with 3" pipes no cat. haha
Old Dec 6, 2009 | 11:58 AM
Mike's 77's Avatar
Mike's 77
Well QT, I'm not copyin you, more competing! But I also just want it a bit louder and meaner sounding! I'm thinkin I may just leave the FM's on for now and just do headers first, and then if I end up wanting louder I'll try glasspacks, or if I really wanna go all out, cutouts! And mine will be w/o cat as well since it's never had one and not required like yours if it's registered down here.
Old Dec 6, 2009 | 05:36 PM
Kalve's Avatar
Kalve
you could do 4" exhaust & headers. An are you going to install a shift kit?
Old Dec 6, 2009 | 06:36 PM
Kennewick's Avatar
Kennewick
Just run open headers!
Old Dec 7, 2009 | 10:57 AM
RacerCoast's Avatar
RacerCoast
If you're not concerned about it being to loud, but want/require a muffler you might give a look at these Schoenfield's, they give a full 9 decible reduction in sound and are a full 6 inches long!!!
Old Dec 8, 2009 | 04:14 PM
Mike's 77's Avatar
Mike's 77
I'd love to run open headers, but I wouldn't be able to get it thru emissions every year like that. Are those Schoenfield's a muffler? It looks more like an exhaust pipe tip. I've never heard of them before, have you used them?
Old Dec 8, 2009 | 05:18 PM
Q's 86's Avatar
Q's 86
theres a reason mine will never be registered down here haha and the schnofelds look sweet might look into that haha
Old Dec 8, 2009 | 06:37 PM
RacerCoast's Avatar
RacerCoast
I sure have used them, on my race car!!! They are actually a muffler for a sprint car or an open wheel modified, I have always welded them directly to the headers. They are available from many racing shops, or you can order them through Speedway Motors. And yes, they are pretty much designed like an exhaust tip with a straight through design, set up to attatch directly to a 3" or 3.5" collector, but they are available in a few other configurations.
Old Dec 11, 2009 | 11:42 PM
NW 150's Avatar
NW 150
how do they sound cause i had those in mind? could you post a vid of it runnin?
Old Dec 12, 2009 | 11:34 AM
Kennewick's Avatar
Kennewick
This thread is not realistic any more. But have fun.
