400 rebuild
Old May 24, 2000 | 04:18 AM
jowilker's Avatar
jowilker
400 rebuild
Old May 24, 2000 | 07:26 PM
Cruiserguy's Avatar
Cruiserguy
400 rebuild
What does the little keeper washer on the oil pump drive shaft do? Does it keep the shaft from going to low into the oil pump? What if I install the shaft without it? I already put the pan on and don't want to remove it unless it is necessary. But I don't want to mess up a new engine over something so minor. I assume that it goes keeper down. Advice please.
Thanks
Rich
Old May 24, 2000 | 11:34 PM
FORDTRUCKMAN1976's Avatar
FORDTRUCKMAN1976
400 rebuild
this retainer keeps the driveshaft in the oil pump when you remove th distributer. if it's not there and you, at some point, have to remove the distributer there is a good chance youll pull the driveshaft out of the pump and drop it into the pan-- that would really suck
Old May 26, 2000 | 05:19 PM
FE427TP's Avatar
FE427TP
400 rebuild
sorry cruiser but I strongly reccomend you fix it and take the pan off, it's a do it now while you can, or do it later when it's harder thing
