Charging issue?
Old Dec 11, 2009 | 11:00 AM
drivembig's Avatar
drivembig
Charging issue?
I have something that concerns me a little about my truck. When I first start it up I noticed that the lights stay dim and the alt guage is very low for a little while. When it kicks in the lights brighten up and the guage goes to normal.
It's my understanding that the voltage regulator regulates when the alternator needs to send voltage and when not to. Is this correct?
If this is correct, then I would think that just after cranking the alternator should be up pretty high.
Could this be a voltage regulator going bad? I wouldn't think the armeture or the brushes because if it was one of them then it should be doing it all the time.
Any thoughts would be appreciated.
Old Dec 11, 2009 | 11:04 AM
RRranch's Avatar
RRranch
It's just the glow plugs drawing a lot of amps. When the glow plug relay turns off then everything brightens up. If you have fresh batteries and good clean and tight connections it will minimize how much you notice it.
Old Dec 11, 2009 | 11:20 AM
Action4478's Avatar
Action4478
The alternator is commanded By the PCM ,(IIRC) to start charging 20 -30 seconds after startup . So what you see is normal..
Old Dec 11, 2009 | 03:24 PM
drivembig's Avatar
drivembig
Ok, thanks for the info.....I didn't even think about the glow plugs still going.....first diesel....I'll get used to the norm eventually. Thanks.
Old Dec 11, 2009 | 04:15 PM
MADVAN's Avatar
MADVAN
Originally Posted by Action4478
The alternator is commanded By the PCM ,(IIRC) to start charging 20 -30 seconds after startup.
What????????
Give me some of what your drinking!!!
Agree. The charging system is at max. Then it spikes as the gp's go off.
It elevates more as batts age. (higher voltage drop).
Bill
Old Dec 11, 2009 | 04:29 PM
Action4478's Avatar
Action4478
TJ told me he noticed it during testing , I took it to be true ...
If true It has to be commanded by the PCM ...
You should have used these ...:
Old Dec 11, 2009 | 04:51 PM
MADVAN's Avatar
MADVAN
I changed my mind. I want what Tj was drinking!!!
I need some antifreeze in me!!!
Bill
Old Dec 11, 2009 | 04:57 PM
Action4478's Avatar
Action4478
IIRC .. It had to do with too much strain on the charging system starter just being used & while the GP'S were heating up ...Made sense to me ...
And the back of the seat was hot ...(remind me to tell you that story )
Old Dec 11, 2009 | 09:12 PM
joe_13894's Avatar
joe_13894
You're getting confused by sooperdoody truck dual alternator systems.
On our trucks the alternator output is ~90 A at idle and 130-150A at high RPM. The glow plugs draw 160 to 180 A. The lights dim down because the glow plugs draw more than the alternator can output leaving a heavy draw on the battery. Once the glow plugs turn off the alternator can bring the system up to 14.2V.
On the sooperdoody dual alternator systems, ONE of the two alternators is disabled while the glow plugs are on. On the dual system the alternators can crank out more than glow plugs. If both alts were on when the glow plugs shut down, the voltage would surge so high that it would blow things up so Ford only lets one run.
Old Dec 12, 2009 | 10:49 AM
Action4478's Avatar
Action4478
I was parroting info from a conversation with TJ .. , You are most likely correct , what you say makes sense . He could have been talking about a SD ..
Keep in mind ..., I can hide my own Easter eggs .....
Old Dec 12, 2009 | 10:59 AM
c00nhunterjoe's Avatar
c00nhunterjoe
yup, you can hold out trucks to about 1100-1500 and the gauge will show normal with the glow plugs on
