Noticed my GPS don't cycle while motor warms. Thinking this is why it runs so rough until normal temperature is reached. Could this be the pcm or a sensor? The plugs and relay are working. Help!
maybe the EBPV?
I didn't think the GP's cycled once it has run it's 1-2 minute course on first ignition.
It may be the oil cooler too but I doubt it....but I don't know,lol
I'm in southwest Arkansas. Can anyone tell me what the little square circuit board with four pins located between fuel filter and the oil reservoir for the HPOP does?
If it is this one you are referring to then it is the "Water In Fuel" electronics ...
