Extremely Cold Blooded
Thanks
"First diesel ive owned"
the first thing with blue smoke is check the oil level.
next remove oil fill cap and start engine. Does it puff smoke from the oil fill?
If it does then you need to do a blowby test also knowen a crankcase pressure test. also if you remove the exhaust outlet from the back of the turbo see if its full of oil. all this is assuming your smoke is really blue. As far as what is sticktion.
Here is the post taking strait from bismic (mark)*
FYI -
Typically when one injector fails, we find that the engine is hard to start and is low on power. If two injectors fail starting will be very hard or the engine will not start at all. If you do manage to start the engine, it will be very low on power.*
You also need to use synthetic oil (5W40), change the oil often, and get the latest flash -
The main reason why the 6.0 is so picky about oil is because it is totally reliant on two electromagnets to shuttle the spool and control the oil to the injectors. The 7.3`s use a electromagnet also but a spring to return the poppet to the closed position. Obviously the spring will work much better to "cut" through the thick oil and close the oil flow.
Not only will running oil with too thick of a viscosity cause rough starts. But this also will interrupt the shuttle action of the spool causing injection timing to be retarded causing poor performance and decreased mileage until the oil is up to full operating temperature.
There is a small spool valve in the top of the injector that controls the flow of high oil pressure fed to the intensifier piston in the fuel injector. That spool valve only moves .017", back and forth, on and off every time the injector fires.*
Many factors play in to how well that valve works such as, oil temp, oil quality, normal wear, ambient temp, and many others. As this valve ages it polishes itself inside the bore of the spool valve and as the spool valve slams back and forth it can set up the condition like a suction cup, hanging the valve to one side or the other.*
This uncommanded uncontrollable condition is called stiction (or oil latching). Mostly its a rough run cold condition but in severe cases it can be a no start or pretty harsh misfire condition. Oil that stays inside the valve on a hot engine shutdown and is allowed to cool slowly in the injector can aggravate the condition on restart, so the newest reflash uses inductive heat after shutdown to keep the oil warm, keep its viscosity low, and maximize the oil flowability to purge the oil from them. It has worked fantastic. It is an excellent preventative measure.
I put about 50 miles on it this afternoon and it has smoothed out a bunch. There were still a couple of times where it was missing a bit but nothing at all like what it was before changing the t-stat.
Lastly, I assume only the dealer does the flashing. Is there a way to tell if it has been done already? What is a reasonable charge for having the firmware flashed?
Thanks again!
