Nitrate level
Old Dec 10, 2009 | 09:12 AM
Gun-Driver's Avatar
Gun-Driver
Nitrate level
Got a letter from Ford about coolant maintenance. The letter is confusing, it states...
*If nitrate level is between 300ppm & 800ppm add supplemental additive.
*If nitrate level is below 300ppm flush engine with iron cleaner (VC-9) & refill.
*Do not add supplemental additive to new coolant or if nitrate level is above 800ppm.
What should the nitrate level be?
Is high bad or is low bad?
Old Dec 10, 2009 | 01:09 PM
UGA33's Avatar
UGA33
Low is bad.
Old Dec 10, 2009 | 01:20 PM
ljutic ss's Avatar
ljutic ss
1200 PPM is the ideal number.
Old Dec 10, 2009 | 03:42 PM
bpounds's Avatar
bpounds
And if it is over 800, do nothing.
Old Dec 10, 2009 | 04:58 PM
ljutic ss's Avatar
ljutic ss
And when it gets to 4,000 you must flush the system.
Old Dec 10, 2009 | 05:59 PM
bpounds's Avatar
bpounds
I had no idea it could even go that high, but I'll take your word for it.
Old Dec 10, 2009 | 07:21 PM
ljutic ss's Avatar
ljutic ss
I am taking Wix Filtration Corp. data on my test strip bottle which is
0 PPM charge(1 pint/4 gal.
200 PPM recharge (1 pint/4 gal)
500 PPM maintenance dose (2 pint/20 gal)
800 PPM maintenance dose (1 pint/20 gal)
1200 PPM ideal
4000 PPM flush.
Looks like the 20 gallon figures are for over the road coolant systems.
also on the PH test anything reading under 6.5 or over 11 needs immediate attention.
Old Dec 10, 2009 | 08:06 PM
Gun-Driver's Avatar
Gun-Driver
Thanks guys,
Mine tested at 1600ppm, so I guess I'm still good for awhile.
It is confusing though low is bad but too high is bad also!
Old Dec 10, 2009 | 08:13 PM
03pwrstrk's Avatar
03pwrstrk
How do you test the coolant ,where are the kits available?
Old Dec 10, 2009 | 09:10 PM
ljutic ss's Avatar
ljutic ss
NAPA sells them, Autozone and Pep Boys do not stock them.
steveg_nh
6.7L Power Stroke Diesel
22
Mar 7, 2021 10:02 AM
queen of spades
Sep 21, 2015 09:10 AM
p_arbor
Jan 14, 2014 10:56 AM
bismic
May 10, 2012 08:50 AM
Andywk
Mar 14, 2003 09:05 PM
