94.5 flywheel
Old Dec 9, 2009 | 07:23 PM
jakemb's Avatar
jakemb
94.5 flywheel
another question about my psd project.keep in mind cash is a bit of an issue atthe moment.my truck needs a flywheel badly.i have anew takeout oem flywheel with almost 0 miles,was a warrenty deal long while backhey were diagnosing a ruff idlead ended up changing flywheels twice.if i remember correctly 5\8 rotation was ok,both came in new at almost that much. question is has anyone ever bolted the two halves together to make a solid flywheel ? does stock clutch have springs,to allow this
thanks
anyone else have trouble typing on this forum? i use this computer all day and when trying to type in this box it misses letter and can not go back all the time to correct because it erases the letter beside it,no problem typing anywhere else on th net,my problem here?
Old Dec 9, 2009 | 08:34 PM
Talyn's Avatar
Talyn
no problems typing buddy.
I sometimes double post, but thats my connection.
Most likely your browser, or an older slower computer. I can type faster then most older computers.
As for rigging up a DMF. I had wondered this myself, and got a big fat "NO".
So if you want it to last, you need to get an SMF and a new clutch.
You could pick up an organic kit from valair pretty decent.
All the parts from valair are made here in the US and they assemble the clutches by hand.
Big-Sarge
6.7L Power Stroke Diesel
47
Jan 17, 2024 10:32 PM
1972-34ton
Electrical Systems/Wiring
15
Dec 29, 2018 09:30 AM
speakerfritz
Oct 24, 2015 10:56 AM
e250blex
Apr 8, 2015 07:21 PM
98SurplusExpy
Feb 4, 2010 11:26 PM
