Sponsored by: Real Truck
Front end sqeaks...................
Old Dec 9, 2009 | 06:33 PM
HMS's Avatar
HMS
The front end on my brand used 00 F250 4 X 4 with 94,000 miles has started to squeak or maybe groan. Started after a load of concrete bags, 900 lbs, and pulling a heavy work trailer. It squeaks when hitting bumps and uneven areas while driving kind of like an old buckboard or something. There doesn't look like there is much to grease on the front end and the ball joints are nice and tight. What gives and how do I cure the problem?
Howard
Old Dec 9, 2009 | 06:39 PM
Rugby3's Avatar
Rugby3
More than likely it's your bushings. Break out the air tools or Popeye arms and replace them.
Old Dec 9, 2009 | 06:45 PM
HMS's Avatar
HMS
Which bushings?
Howard
Old Dec 9, 2009 | 07:31 PM
MoBill122's Avatar
MoBill122
Papa Smurf
Could be missing the nylon slides on the ends of the leaf springs.
Old Dec 9, 2009 | 07:37 PM
FireMe's Avatar
FireMe
Have someone (or two people) bounce the front end up and down while you lay under the front end looking for the source of the noise.
I would look at:
Spring tip isolators
Spring bushings
Sway bar bushings
Sway bar end links
Steering linkage
Usually you can feel the suspect part vibrate when it makes noise.
Jay
HighRiskJob
1997 - 2003 F150
Sep 16, 2014 09:22 AM
hojolabo
Dec 19, 2009 04:49 PM
Howard
Jun 15, 2005 09:53 PM
Howard Fish
1947 and Older Ford Trucks
Aug 18, 2004 12:29 AM
Howard
Mar 27, 2001 10:50 AM
