rear axle options
Old Dec 9, 2009 | 12:38 PM
Farmboy46's Avatar
Farmboy46
rear axle options
OK so i have read on this site that a 58-72 9 inch is a direct bolt in for my 46 ford truck. I thought that the 72's were just as wide as the 73's and up. Anyway i went to the junkyard found a 71 ford truck and measured the width, it was way off, later i found a 58 ford truck with no axle, kinda bummed me out, but i measured the leaf springs from side to side and from what i found a 58-61 will work. Does anybody else know anything more about this?
Old Dec 9, 2009 | 02:52 PM
3Mike6's Avatar
3Mike6
Don't worry about leafspring location, that's a real easy fix to relocate the perches.
I'd more concerned about WMS to WMS, if you're planing on running the same wheels.
Old Dec 9, 2009 | 07:00 PM
Farmboy46's Avatar
Farmboy46
ya the spring perches arent the problem at all, a person can do anything with a torch and a welder. I was just wonderin if there is a car rear axle or anything that would be the same width, and as far as the bolt pattern or anything else goes thats easily fixed also.
Old Dec 10, 2009 | 08:28 AM
COMPLIT1107's Avatar
COMPLIT1107
Finding the right Ford Rear end is the PC Choice here, but when I looked around (without the benefit of these forums ) I found that the 68-69 and maybe up to 72 Chevelle/GTO were the correct overall width. Unfortunately they were coil-overs, but like you said "All you need is a torch". Here's a pict. (4.11 gears, posi - haven't installed the upper arms yet.)
Good luck on your project !
P.S. You'll need donor perches...
77f2504by4
Oct 27, 2015 07:25 AM
muscletruck7379
May 3, 2015 07:17 PM
mr46
1947 and Older Ford Trucks
Nov 3, 2014 11:41 PM
havi
22
Feb 17, 2008 02:57 PM
banjopicker66
Mar 21, 2007 09:30 AM
