how long to wait before adding coolant?
Old Dec 8, 2009 | 09:01 PM
little dutch's Avatar
little dutch
I just replaced the thermostat housing, how long should I let the permatex set on the gasket before I add fluid and start it up?
Old Dec 8, 2009 | 09:31 PM
Hitokori's Avatar
Hitokori
i would give it at least an hour it should say on the box it came it... and if u used a gasket u should be good right off
Old Dec 8, 2009 | 10:08 PM
little dutch
ok, used a gasket, so I went ahead and added it and warmed it up. I naturally do not have the box and I don't see anything on the tube.
Thanks for the reply.
Old Dec 8, 2009 | 10:15 PM
Hitokori's Avatar
Hitokori
yea since u used a gasket and tightened it down its technically sealed only thing the blue glue does in that case is "extra insurance" for like little nicks in the goose neck or on the block.... glad i could help
Old Dec 9, 2009 | 02:43 PM
little dutch
Thanks for that. to re-phrase, the gasket sealer is just a leveler, and the gasket does all the real work. I am stoked the truck is running finally.
Old Dec 10, 2009 | 12:25 PM
TexasGuy001's Avatar
TexasGuy001
If its cold or wet outside, I would wait longer.
Thurter
May 15, 2017 11:15 AM
chickfisher69
Jan 29, 2016 07:33 AM
dgamblin
Sep 11, 2015 01:30 PM
audimotion
6.7L Power Stroke Diesel
17
Dec 16, 2011 01:59 PM
