vacuum modulator
Old Dec 8, 2009 | 06:24 PM
marybeachfairy's Avatar
marybeachfairy
vacuum modulator
could anyone direct me to a diagram for my transmission...86 ford f150 at(4speed od) i dont know exactly which trans it is...is there somewhere i can look at diagrams...i am trying to figure out exactly where the vac. mod is...i have a 91 explorer...is it similar?? and how to get at it...in the explorer you pull up some panel under the carpet but thinking thats not going to be the case here. any help thanks
Old Dec 8, 2009 | 06:35 PM
bghnkinf250's Avatar
bghnkinf250
You most likely have the AOD. These do not use a vacuum modulator (as far as I am aware). These use a TV cable instead, which is hooked to the carb. I habve no experience with these types of trannies, but there is a lot of info here on them.
Old Dec 8, 2009 | 06:49 PM
marybeachfairy
i dont exactly have a carb...this truck is a hybrid throw together deal...not sure what a tv cable is either...but i know the trans is an 86
and pretty sure you are right about which trans it is because i sure did not see a vac modulator on that thing
i did the filter change but i didnt empty the torque converter...not sure how...have to look it up
Old Dec 8, 2009 | 06:52 PM
marybeachfairy
Ford AOD Transmission
found this-sort of interesting
Old Dec 8, 2009 | 07:20 PM
bghnkinf250
Soooooo what do you have then? Is it injected?
Old Dec 8, 2009 | 09:54 PM
Franklin2's Avatar
Franklin2
Here's a site with some good info. Get it right before you drive it very far, or you could ruin it.
Main Tech Help Page - Baumann Electronic Controls, LLC
erik68
15
Apr 24, 2014 07:59 PM
kupiec20
Oct 14, 2013 08:14 PM
Nedcampion
1947 and Older Ford Trucks
32
Dec 16, 2009 06:34 AM
