Block Heater Failure!
Old Dec 7, 2009 | 06:00 PM
Airzima's Avatar
Airzima
Unhappy Block Heater Failure!
I had the truck plugged in, and when I went to start it this morning, it was ugly. Took me 4 times to get the beast fired up. It was plugged in all night and the temp was 9 above. I begin to wondering if the block heater was working. I checked the plug with my OHM meter and recieved no reading. I then checked my friends 08 powerstroke in the same manner and received a 16.8 ohm reading. What is the probability of the heater failing vs. the cord going bad. It was only 8 degrees outside when I got home and I did not want to take the cord of the truck and ring it out. It is going to hit -5 below tonight, so I will be doing some cycling of the glow plugs in the morning. If any one has had a failure please let me know what it was.
Old Dec 7, 2009 | 07:25 PM
cheezit's Avatar
cheezit
unplug the cord and the block heater and test it there should be close to 15 ohms. Ive not seen a heater go bad yet but down here they almost never get used. Ive seen a few cords fail though
Old Dec 7, 2009 | 07:30 PM
william_04_x's Avatar
william_04_x
Check out where the cord attaches to the BH just above the starter(pass side of motor).. Maybe it's come loose there.. To get a reading of nothing and have it all intact would be hard to believe..
If it's really cold, plug in a 500w halogen worklight and set it about 6" from the bottom of your oil pan facing up.. It won't hurt anything as long as you don't run it over when you leave in the morning..
Old Dec 7, 2009 | 09:14 PM
Airzima's Avatar
Airzima
Thanks for the info, but it is just too damn cold to play troubleshooter tonight. Getting to cold to roll around in the snow tonight to get to it. It will start (I hope) in the morning, and Ford and my extended warrantee will have to deal with it in the afternoon.
Dennis
Old Dec 7, 2009 | 09:31 PM
conger's Avatar
conger
Dennis
It's probably the cord. More than likely it be the male cord end. I had an open cord last year and it turned out to be open just behind the plug end. I just replaced the plug. I hear ya about not wanting to crawl under the truck in the cold. Last week hear it was only -2C. Then we had a storm that dumped a foot of snow with 60km winds. This morning....-34C. I've got a hub that's been acting up, and I've moved it from my "to-do" list to my "screw-it till spring" list.
Old Dec 7, 2009 | 10:17 PM
Zmann's Avatar
Zmann
I did see a post on the element going bad ,, in the same manner a water heater element would fail ,, cross build up so to speak
Old Dec 7, 2009 | 10:44 PM
conger's Avatar
conger
As Cheezit said, not likely the element. Your cooling system has distilled water in it and the Motorcraft gold coolant has chemicals to fight corrosion. You don't have that in a water heater. A simple check with an ohm meter will tell the tale. My money's on the cord.
Old Dec 8, 2009 | 07:44 AM
Zmann's Avatar
Zmann
I agree it's not likley
Old Dec 8, 2009 | 07:17 PM
bigredtruckmi's Avatar
bigredtruckmi
Veteran: Navy
Cord from block heater or maybe the extension cord female end has gone bad. I had that one last winter.
Old Dec 9, 2009 | 08:10 PM
Airzima's Avatar
Airzima
Thanks for all the information. It was the cord. The people on this forum will be the ones I will be trusting when my extended warranty will be expiring in a few months. This forum is invaluable due to the amount of knowledge on this forum from the different issues that we all have dealt with on our trucks. Thanks again
Old Dec 10, 2009 | 12:00 PM
bigredtruckmi
Veteran: Navy
Glad it worked out and thanks for the reply that the issue was resolved.
Old Dec 10, 2009 | 12:37 PM
ranger429's Avatar
ranger429
What was the price for the new cord? I just had a problem with mine last night and spent an hour tracking it down. I believe that my problem is in the connector. I pulled it apart cleaned it and put some dielectric grease on it and it worked last night. -1 reading here this morning so it is a necessity.
Old Dec 10, 2009 | 05:33 PM
nitrogen's Avatar
nitrogen
if the connector is the problem, the solution is a pair of sidecutters. 2 cuts 1 on either side of connector, soldier wires and use shrink tube. as far as the "cord" going bad generally the prob is the male end o the bumper thats exposed to all that nice moisture and salt. grab that sidecutters make 1 cut 3 inches from the plug go to hardware store of your personal preference and buy/install new male end. cost including fuel to go to store less than 5 bucks and it takes15 minutes tops to install
Old Dec 10, 2009 | 05:51 PM
Zmann's Avatar
Zmann
I cut all the connectors out and installed this in the airdam .. unplugs by itself if you forget ,, another plus lol
Old Dec 10, 2009 | 06:21 PM
ranger429's Avatar
ranger429
Thanks Nitrogen. After giving it some thought today I'm going to eliminate the connector and hard wire it like my semi is with one of these plug receptacles. No more fumbling for the cord or tucking it away for the summer.
Just saw your post zmann, where did you find that receptacle? It looks a little smaller compared to the one I found.
