Pull points and strengthening the "crumple zone"
I needed some pull pionts on the front of my 94, I really don't like how the front of the frame looks with the "crumple zone". I'm worried if you start pullin too hard on it, it will stretch the frame. So this is what I came up with.
Its 1 inch plate welded to some 3/8 plate. There are 4 1/2 inch bolts holding it to the frame.
As you can see I drilled two holes in the frame, they are about 20 inches back from the front of the frame. I welded the nuts to the 3/8 plate so its easy as pie to get the bolts snugged down.
These two bolts thread into the 1 inch plate. I drilled and tapped the holes in the front part. I figured it would make it a easier install.
Than I had to cut the bumper to fit over them. I started with small holes and started to open them up, so there wasn't a big gap around them.
Its not the most detailed writeup, but I figured it would give a good idea of how to get a sturdy pull point on the front of these things.
https://www.ford-trucks.com/forums/5...nt-bumper.html that is a bad *** bumper he built i want to build one
