1986 - Replace 460 with 351W
Old Dec 7, 2009 | 09:49 AM
E30tdf's Avatar
E30tdf
My 1986 F250 4x4 T19 just let go a head gasket. Have a good running 351W I want to try in the truck. I have acquired the 164 tooth flywheel, block plate and bell housing I need for the swap.
Questions:
1) What do I have to do to mount the engine, just change motor mounts?
2) Can I use the 460 radiator? (there is no oil cooler to deal with)
3) Any big fuel line routing issues? (not likely)
4) How much will the front suspension rise? (less weight)
thanks for the help
Old Dec 7, 2009 | 01:45 PM
E30tdf's Avatar
E30tdf
I'm sure this is a pretty common swap. I'm just trying to be aware of the parts needed and the amount of work so I can plan ahead and be ready. Maybe someone who has done this swap can chime in. BTW, I don't tow anything that weighs more than 3k, so I'm not concerned about losing some torque. A little better efficiency with fuel would be a bonus.
Thanks
Old Dec 7, 2009 | 03:57 PM
Kemicalburns's Avatar
Kemicalburns
well i dont beleive the clutch will from the 460. the rad should work, you will need 351w frame perches along with motor mounts. is the 351w complete with all its acessories? your taking a huge drop in power by the way an little gain in mpg in that size of truck. a headgasket is far easier to change out then messing with a motor swap in my opinion.
good luck.
Old Dec 7, 2009 | 10:38 PM
E30tdf's Avatar
E30tdf
460 tired
I have accessories for the 351W, but not all the brackets to hang them unless the SB Fords all share the same brackets. I have a bunch of 302 stuff including brackets. I purchased a flywheel and bellhousing specifically for the 351W. Not reusing the 460 clutch.
The frame perch swap sounds like it will be the most challenging parts to find and to install. I guess those will have to come from someone parting a truck or wrecking yard.
Whatever I do it will have to wait a while. We are having an unusual dip in temperatures for Western WA this week. 7 degrees at our place this morning. My shop is pretty darn cold right now. Fortunately, I don't have to have this unit for daily use.
Old Dec 19, 2009 | 10:17 PM
chilsam's Avatar
chilsam
Id replace the head gasket save the headaches.Good Luck!
Old Dec 19, 2009 | 10:38 PM
Gale Hawkins's Avatar
Gale Hawkins
I agree and save a lot of money too.
Old Dec 20, 2009 | 11:39 PM
E30tdf's Avatar
E30tdf
Agreed
Likely just rework my current engine a bit! Makes the most sense overall!
Q: Since my 460 is not using oil at all (not sure how many miles on the current build), why could I not just have the crank turned or polished and install new main and rod bearings. Wouldn't cost that much. Maybe freshen the valve seats also. Then she may last as long as I need her to! In 11 years I have driven her a total of 25,000.
Hunter Nelson
Mar 30, 2016 01:57 PM
1986-460
Supercharger, Turbocharger, Nitrous Oxide & Water/Methanol Injection
Nov 4, 2015 01:51 PM
1986-460
Computer Chips & Tuners
Sep 14, 2015 04:51 PM
FordFETruck
Mar 12, 2012 02:37 PM
the lloyd wards
Mar 7, 2003 05:50 PM
