Sponsored by: Auxito
4x4 problems
Old Dec 7, 2009 | 08:13 AM
MIKE 04 GT's Avatar
MIKE 04 GT
4x4 problems
i have a 2002 screw fx4. the other day i put it in 4x4 and started up a hill and it kicked out and then went back in when i stoped, when i went to take it out of 4wd it kinda jurked out. i later tryed to get it to do it when i got home and it seems to be working fine anyone have a idea if something is wrong. also it has done this befor but i was not positive i gave it time to get fully engaged, but this time i did. any help thanks mike
Old Dec 8, 2009 | 06:25 PM
highteckredneck's Avatar
highteckredneck
have you checked the fluid in the t-case? somtimes it the level is low when you start to climb a hill it will not engauge to 4wd. but on level ground it works fine.
Old Dec 9, 2009 | 08:09 AM
MIKE 04 GT's Avatar
MIKE 04 GT
no but i will check this friday. thanks
Old Dec 12, 2009 | 12:25 AM
fordmerc's Avatar
fordmerc
T-case fluid has nothing to do with 4x4 engagement. You either have a shift motor or vacuum problem.
Old Dec 14, 2009 | 08:17 AM
highteckredneck
well t-case fluid has alot to do with it. mine did the same thing, took it in and thats what the guys at ford told me. why it will do it is news to me, i dont know, but they said if there is a low level, the sensor will not engauge to 4wd to protect the gears or somting.
Old Dec 14, 2009 | 10:58 PM
fordmerc's Avatar
fordmerc
The only electronics that even touch the t-case are the shift motor and the speedo speed sensor wihich neither of them have any idea how much fluid is in the t-case at any time.
mike 55
Nite, Nascar & Other Limited Edition Ford Trucks
Dec 7, 2014 02:12 PM
mikes-bigred
New Member Introductions
Apr 20, 2013 07:46 AM
X_Hemi_Guy
Jul 13, 2011 11:38 PM
mikelane
Feb 20, 2007 07:06 AM
mike86f350
Nov 9, 2004 04:48 AM
