Little Oil Cooler write up!!!
#32
WOW, this winter has been filled with oil cooler o-ring failures!!!!!! this is amazing... i'm sure glad i went through with writing this up. i didn't know that many people would find it useful. glad its been helping so many people, but wish there wasn't so many oil coolers leaking this winter!!!
#33
#34
very good write up! the reseal kit from diesel specialists inc. for $59. is cheaper than going to international and ford. o rings were about $10. each at international and the one gasket at ford is $27. the guy at international gave me the other gasket for free . i dont know what it costs. i'm still yet to reseal it . parts are sitting on the seat, but it still leaks . thought it would have at least helped out.
#35
Travis, thanx for the write up .. I had to tacle this on my truck a day or so after youre posting and have to say ur info helped alot!!! My issue was not o rings... the rear cap(filter side) was cracked due to rust on the outside of the cooler tube the rust expanded and cracked the rear cap. I replaced the cooler tube,rear cap,o rings and gaskets....go to go now!!!!
#36
strokin'_tatsch / all
I posted the following in another "tread" (as i was told). Is this the same thing as what your saying.
Thanks
"Hello all.
I've got a 93 F350 7.3L non turbo. I noticed some oil leaks the past few weeks so I changed the oil and replaced broken seal on drain plug thinking that would fix it. I live in San Antonio Tx. Never gets cold here. Last night it got in the low teens. Finally got it started and noticed it was really bleeding from the oil filter housing close to the front. Had to take the truck so I grab 4 Gals of oil and headed out. Got to work and check. Not bleeding just a few drips. Let it set and checked oil. Plenty of oil on dipstick. I’ve read previous posting. Seen some diagrams none of which looks like what I’ve got unless it is the front part that attaches to the tube (about 2 1/5 in dia.) that connects to filter. It looked like it was leaking where the “tube” connects to the front bracket assembly. HELP please"
Thanks
"Hello all.
#38
Thanks
"Hello all.
Thanks
"Hello all.
Bring it on dude. now that Roy and I did mine i'm pretty sure another one wouldn't hurt. how bad is it leaking?? bad enough that we gotta do it in the cold?? i'd use the filter side end cap from one of your later model coolers too.
#40
#41
I think I'm losing it.
I had the cooler resealed and now it leaks only when trucks sits in 20 something degree weather. The shop is telling me it could be the timing chain is warpedI was advised to just plug it in and it should be ok....
WTF Has anyone had this situation happen to them?
Any and all help would be greatly appreciated.
#42
#43
#45
Thanks Rubber Duck,
I might be in the wrong forum the truck is a 2002 F 550
I spoke with the shop for quite a while last night..Tried some logic
(If the truck came in with the leak and the o rings were split. You changed the o rings
and 1 day later leaked in same place and same amount of oil....Could it be possible that your tech nicked the o rings on reinstall) and the silence was deaf fining..
So today they will remove. reseal and replace the seals
Stay tuned kids this should get interesting..
