trouble codes, tow haul light flashing
Old Dec 6, 2009 | 08:53 PM
timhugg's Avatar
timhugg
Hi Guys,
Just hooked up my autoenginuity program today and pulled some codes. Anybody know where to start with these numbers? any help appreciated.
Thanks,
Tim
P1876 transfer case 2 wheel drive solenoid circuit failure
b1483 brake pedal input circuit failure
P0500 vehicle speed sensor A ( are their 2 of these? i already replaced one on the rear pumpkin)
B1201 Fuel sender circuitfailure. Fuel gauge is working
P0705 Transmission range sensor circuit malfunction.
I tried clearing these once and they all came back.
Old Dec 6, 2009 | 09:25 PM
timhugg's Avatar
timhugg
?????????help
Old Dec 6, 2009 | 10:59 PM
HD Rider's Avatar
HD Rider
I wish I could offer more help. If everything is working and you keep getting these codes I would check the simple things first.
Make sure battery connections are clean and tight.
Check all ground connections including engine, chassis, and body, to make sure they are clean and tight.
Paul
Old Dec 6, 2009 | 11:19 PM
guzzle92's Avatar
guzzle92
I agree that it sound like a faulty ground. I was getting the P0500 even after replacing the sensor on the 3rd member. It turned out to be a harness ground in front of the driver's battery. Since you are getting a couple related to the transfer case/tranny, it could be one along the harness under the truck.
Old Dec 7, 2009 | 05:17 AM
timhugg's Avatar
timhugg
Thanks fellas, I will check those first.
Old Dec 7, 2009 | 08:48 AM
Robert6401's Avatar
Robert6401
Tow/haul light? Do you mean the O/D Off light on the shifter? If so, that's indicative of a transmission issue. I can't help with the AE stuff. Good luck.
Old Dec 7, 2009 | 11:16 AM
timhugg's Avatar
timhugg
Is there more than 1 speed sensor on a 2002 f350? Also, where are the shift solenoids located on the truck?
Thanks,
Tim
Old Dec 7, 2009 | 12:08 PM
PaysonPSD's Avatar
PaysonPSD
Thanks,
Tim
Besides the VSS on the rear pumpkin there are two on the tranny. One is mounted toward the front and monitors the input shaft speed and the other is mounted toward the rear to monitor output shaft speed. I believe those two are interchageable.
The shift solenoids are in the tranny.
Old Dec 23, 2009 | 09:54 AM
timhugg's Avatar
timhugg
Are the solenoids in the tranny user accesible, or is this a major job to replace if they are bad?
Old Dec 23, 2009 | 10:00 AM
Hiflyer746's Avatar
Hiflyer746
What makes you think they are bad? have you watched to see if they work? i believe the sequence is 1 in first, 2 in second. . . 1&2 in third, none in fourth. . . something like that. or its 1 in first, 1&2 in second and 2 in third. . . can't remember.
Timmy
Old Dec 23, 2009 | 04:12 PM
timhugg's Avatar
timhugg
Dont know if they are bad, just a general question.
Old Jan 6, 2010 | 06:16 PM
timhugg's Avatar
timhugg
would a shorted or open harness in the steering column activate the od light? Ifso, how much of a job is it to take apart and check?
Old Jan 6, 2010 | 07:38 PM
Vinford's Avatar
Vinford
My OD light flashed 2 diffrent times..........both times it was new tranny time.
Sorry but its a possibility.
Old Jan 6, 2010 | 07:49 PM
Kwikkordead's Avatar
Kwikkordead
That's a lot of seemingly unrelated codes so I'm going with what Guzzle is saying and look for corroded wiring.
Do you live in an area where they salt the roads in winter?
Old Jan 6, 2010 | 08:35 PM
timhugg's Avatar
timhugg
Yes I Do.
The funny thing is, this light never flashes underway. It blinks when you start it until you put it in gear, and then it goes out. Sometimes it never even comes on. I would think with a serious tranny problem, it would flash all the time. The one code i mentioned above said something like PRNDL input.
