very stuck glow plug
Old Dec 6, 2009 | 08:43 PM
bkbkbkbk's Avatar
bkbkbkbk
Smile very stuck glow plug
I soaked it in Liquid Wrench for three days, cranked engine over, tried pliers to pull the filament out to no avail. Does anyone know a trick to get this out? Any help would be appreciated.
Old Dec 6, 2009 | 08:50 PM
95_Dually's Avatar
95_Dually
Here is some reading for you.
Originally Posted by RÖENTGEEP
I have this write up saved in my PC, maybe helps you a little.
Glow plug removal article fficeffice" />>>
I am writing this article for a few reasons.
Firstly, because I was asked by a number of guys if there was a way to remove glow plugs so as to not break off the tips inside the engine. The short answer is No, there isn't any guarantees, . However, before you all feel like just walking away and selling your "baby" for scrap, there are a few things that you can do.
Secondly, since I was unlucky enough to have to go down this road and ended up having to pull both heads off my engine to retrieve broken off glow plug tips, I figure that even if I save one guy from having to do the same, then my time will be well worth it.
I have heard of all kinds of ways to remove the glow plugs, especially ones which are stuck. I've heard of guys just unthreading them and then starting the engine, and letting them "blow" out. Apparently this sounds a lot like a gun going off, and if you don't mind stripped thread holes, and a few holes in your hood that resemble bullet holes, then maybe this is the method for you(not me!). I have heard one guy claim that he filled his cylinder with water, and cranked the engine, and the water being forced out of the cylinder "blew" the plug out (not me!) I've also heard of guys who just crank on 'em and if they break off, then so be it, they just start 'er up, and hold the throttle at governor speed until the bits come out somewhere!! I suppose that could work, but one fellow sent me a pic which shows what can happen if you try this method. This is a pic of his removed oil pan after a glow plug tip failed to "pass". I was lucky, I only split one piston, and at least my engine was salvageable!!
What happens when you try to pass a glow plug tip!!
So, one has to understand what it actually looks like inside the heads where the glow plugs are positioned. It's really difficult to try to explain what/why these broken off tips become a problem, but I drew a diagram that I hope sort of helps others to "see" what the problem is. The glow plugs are mounted into an area of the heads called the "pre-cups" They are designed to help "swirl" the fuel air mix before it enters the cylinder and start the ignition of the mix. However, by their shape, if a glow plug tip breaks off, it becomes very hard to reach once it is inside the pre-cup chamber, and if it falls down into the cylinders, then it becomes even more difficult. So far, I have not heard of one viable solution to this problem, and I have not heard of one person who has come up with a way of getting these bits out of the engine other than pulling the heads off, or taking a chance on the kind of damage as seen in the previous photo, and starting it up. Have a look at the following pic (lousy artistry) and you'll see what I'm getting at....
pre-chamber approximation
You can see that if the broken off tips/bits make their way down into the cylinder, since the hole is only about 1/8" in diameter, there's no tool I know of that can go around the corners and down into the cylinder to retrieve these pieces, and somehow grab them and pull them back up. Remember, that this all has to be done from above, outside the engine, without any direct vision of what's going on.
here is the real pre-chamber as seen removed from the head. Note the glow plug size, and the tiny hole where it is mounted in the head. The other larger hole is where the injector tip is mounted. If you look closely, you can actually make out some tiny cracks developing in the pre-chamber insert surface itself.
pre-chamber, plug removed
pre-chamber, plug in place >>
Ok, so have I got you completely depressed yet? Well, I think I may have come up with something which may occasionally get someone out of trouble. It did work for me, but not until after I had dropped 2 glow plug tips (one in each side) into the cylinders and had no choice but to remove the heads to get them out. It may not work every time, and is not a guarantee, but like I said previously, as far as I'm concerned, even if it saves 1 guy from having to pull the head(s) off, then it was worth my time to write this. >>
Put simply, it is this. When the pistons are at the top of their travel (top dead center or t.d.c.) there is virtually no space in the cylinder where the glow plug tips can go. They can not drop down out of the pre-chamber into the cylinder bore.. Since the hole where the injector goes is quite a bit larger than the glow plug holes, I found that with a strong suction device ( I used a powerful shop vac) attached to the injector hole it is possible to suck the tip up/out of the injector hole. A little compressed air blown into the glow-plug hole can also help to swirl air around and hopefully drive out the broken off tip, but one must be careful to prevent rotation of the engine using a large socket on a bar or something, because the high pressure air can actually push down on the piston and allow the engine to rotate, and the bits will then fall down inside.
So, for each cylinder that you are removing the glow plugs from you need to get the piston to t.d.c. first before trying to remove the glow plug. To do this, you need to find the timing pointer, and the line scribed into the side of the harmonic balancer. When these are lined up with each other, it is an indication that #1 piston is at t.d.c.! Ok, next, for each 1/4 turn of the engine in a clockwise direction as seen from the front of the truck, the next piston in the firing order will be at t.d.c. The firing order of the 6.9l engine is 12734568. Each piston is mated with another for balance. So, this means that when #1 is at t.d.c. so will another. It happens to be #4. 2/5, 7/6, 3/8 are matched too. Thus, when #1 is at t.d.c. you can also work on #4, turn 1/4 turn clockwise, and then you can now work on #2 and #5 and so on....
That's it!! I have now made it a practice and I recommend it to anyone, that every time you decide to remove those glow plugs, to follow this procedure, and you will at the very least lessen your chances of getting into trouble. Unless your controller has failed and left the plugs on too long, chances are they will just come up/out without any problems at all. They do get carboned up sometimes, and a bit of wd40 squirted down on them can sometimes help.
Finally, this is just my personal experience, but I did do some testing on 4 brands of glow plugs, and found that when hooked directly to a battery and left, that some plugs burned out in as little at 10 seconds, and other were still intact after 40 seconds. But, even worse, were the ones that when they did burn out, distorted or bent such that they would be all but impossible to remove even using the methods I've described above. The Autolite brand was the worst. 10 seconds and they died, and distorted!! These were the ones I had to pull my heads off to recover. I do not recommend anyone use this brand!!
check this out
Champions were not much better, and they died in about 12 seconds. Lucas and Bosch both did better, lasting about 20 seconds, and finally Beru (motorcraft) I left on for over 40 seconds, and they didn't distort, or burn out. There is one other type, that are apparently a modified to fit Gm/Ac glow plug which is called "constant duty". Advertising says that they can be left on indefinitely, and will not be harmed!! While at $38 each Canadian, I didn't want to take a chance on burning one out, but I have put them in my truck, and they have worked very well for me. I consider the high cost insurance. The only place that I know of where they can be purchased is in Canada at Diesel Auto services but he will ship them to the U.S. too.
So, in conclusion, I can say there is no guarantee that every time you remove glow plugs they will come out intact. But, if you take your time, and follow this method described above, you may improve your chances of not learning first hand how to replace your own head gaskets!!! Best of luck!! >>
Here is the thread I got this from. I hope this helps.
https://www.ford-trucks.com/forums/8...g-the-gps.html
Old Dec 6, 2009 | 08:59 PM
helifixer's Avatar
helifixer
I have a couple engines running with a dead glow plug in them, if it is just one it only smokes a little until the engine warms up. they will start just fine in normal conditions with 7 good glow plugs. just leave the dead one unplugged under the valve cover
Old Dec 6, 2009 | 09:06 PM
bkbkbkbk's Avatar
bkbkbkbk
Thanks so much the filament is still sticking out of the head cant git it to budge with the limited amounted of pressure that im able to pull on it
Old Dec 6, 2009 | 09:12 PM
helifixer's Avatar
helifixer
have you unscrewed it? if so can you move it up and down any? if you can move it up and down any go buy a NEW pair of needle nose vice grip pliers (get vice grip brand! not cheep ones) and keep it flooded with pb blaster and pull strait up than tap back down keep repeating (for hours) it should move a little more each time you ca even get a little prying action an the pliers but keeping the pressure strait is a must, if you bend the glow plug it will break.
Old Dec 6, 2009 | 09:25 PM
bkbkbkbk's Avatar
bkbkbkbk
was lucky in one way when i was backing it out the casing , The tip broke off the top and almost made its way in to the head when i pulled the socket off the plug
Old Dec 6, 2009 | 09:35 PM
95_Dually's Avatar
95_Dually
Good thing you didn't drop it in there. I have heard horror stories of that happening.
Old Feb 12, 2017 | 09:58 PM
GreenMachineF250's Avatar
GreenMachineF250
Stuck Glow Plug Tip
I tried cranking the engine over without the glow plug in and then I put the glow plugs in and let it idle for about an hour with no luck. It was stuck 1.75 inches below the top of the glow plug port.
Finally, I took it on a drive and it quietly came out after about 2 miles. I opened up the throttle on the second mile. It put a small hole in the valve cover but there it was sitting in the bottom of the cylinder head when I removed the valve cover.
A huge thanks to Dale at Tymar for spending two hours on the phone developing a plan of attack for this problem. He is a solid guy.
Old Feb 12, 2017 | 11:58 PM
Kingkong0192's Avatar
Kingkong0192
Nice! If you have a welder you could just fold that flap back down on the valve cover and weld it closed then grind it smooth.
Will save you the cost of a new valve cover.
Old Feb 13, 2017 | 06:15 AM
GreenMachineF250
That is a good idea...I want to keep this battle scar. I took you up on your suggestion...just got back from the welder.
Old Feb 13, 2017 | 10:12 PM
ProjectDually's Avatar
ProjectDually
I think one question that hasn't been addressed yet.. Was is it a Motorcraft or Autolite? I know it was mentioned in Sam's post, but I'm curious as to what brand it was.
When I did my first GP change, I found several Autolite's mixed in the bunch, and was very lucky to retrieve them, what with all the horror stories I've read about them swelling.
Glad you got it out thought!
Old Feb 13, 2017 | 10:23 PM
fordpride's Avatar
fordpride
Good thing it went up and not down. Glad it came out but I do not recommend this method. If it would have fallen down you'd have a 1k lbs paper weight.
Old Feb 18, 2017 | 08:41 AM
GreenMachineF250
You called it...it was an Autolite.
In hindsight I would follow the advice of this video:
Glow Plug tips and tricks
For intact but stuck glow plugs this video really helped:
7.3 glow plug stuck / broken removal tip
I noticed the more days I let the loose (unscrewed) but stuck glow plugs marinate in Free All the easier they were to remove, with minimal pulling.
For the glow plug tip I had broken off inside the port, I let it sit in Free All for at least 5 days and the fluid level never dropped inside the port. It was a last resort before pulling the head.
Old Feb 18, 2017 | 11:30 AM
BBslider001's Avatar
BBslider001
That second video really helped. I have to do mine pretty soon just to make sure the PO didn't use bad plugs. I have pulled a few and they were Beru, but I pulled one that was an AC Delco. I am not even sure what that means...LOL
Old Feb 18, 2017 | 11:44 AM
Bubba Jones's Avatar
Bubba Jones
I'm lucky I changed mine when I did. My motor was heavily neglected/Frankenstein before I had it. I had the wrong HPOP on (94/95 need their own special HPOP), missing valves in the oil cooler and also oil filter housing.
All the plugs were Autolite as well. Thankfully, the glow plug relay was dead as well so they didn't get too much use.
spongecop
Dec 16, 2017 01:28 AM
Bearhugger1933
May 31, 2017 10:59 AM
Color sarge
Apr 18, 2017 03:41 AM
Jons13
Aug 4, 2016 12:28 PM
Sdean
Mar 13, 2016 06:23 PM
