Door Rubber
Old Dec 6, 2009 | 02:55 PM
mpuvdd's Avatar
mpuvdd
Question Door Rubber
I'm going to be ahearing new door rubber to my 71 f-250. Could anyone take a pic. or explain how the stuff is applied at the bottom of the door? I think you're supposed to use screws, but how many?
Thanks for any input
Seth
Old Dec 6, 2009 | 04:39 PM
jowilker's Avatar
jowilker
Who's rubber are you using??
John
Old Dec 6, 2009 | 05:16 PM
mpuvdd's Avatar
mpuvdd
I am using the rubber supplied by LMC.
Thanks,
Seth
Old Dec 6, 2009 | 09:22 PM
Danger_Dave's Avatar
Danger_Dave
i cant take any pics but i just did mine with dennis carpenter brand. there are 5 screws holding a metal cover and the rubber goes underneat that. by looking at it you can clearly see this and upon removing the cover you can see it as well.
the screws are probly corroded like mine were and a screwdriver will strip them, so its good to have one of those impact screwdrivers that you hit with a hammer and applies force and torque at the same time.
you use permatex weatherstrip adhesive to adhere the whole strip around the door and then the ends meet halfway under that cover. when your done your gonna have to slam the doors to get them to close but after a week or so they break in and youll have a nice tight seal. the prepwork is the most important part. use brake cleaner and sandpaper to remove all old residue and be working with a smooth clean surface.
Old Dec 6, 2009 | 09:51 PM
mpuvdd's Avatar
mpuvdd
Ok, so I do need the plate that goes at the bottom of the door?
Old Dec 6, 2009 | 11:28 PM
carpenter547's Avatar
carpenter547
is there a difference in quality between the lmc and other brand door rubber? sorry i was thinking about doing this to my truck same make and model but to my memory you guys really dont like lmc stuff.
Old Dec 7, 2009 | 03:44 AM
jowilker's Avatar
jowilker
Dennis Carpenter repops the best rubber, all made to Ford specks, not the cheapest price & ill fitting. IMHO
John
Old Dec 7, 2009 | 08:48 PM
justiz00's Avatar
justiz00
I used the LMC rubber. You squirt the adhesive and lay it down under the door seal plate and insert screws.
Old Dec 7, 2009 | 11:21 PM
mpuvdd's Avatar
mpuvdd
Ya, I ordered the sill plates. Now it makes sense
Thanks guys
Old Dec 8, 2009 | 07:54 PM
Danger_Dave
wow yours didnt have any of those plates on it? a wierd item to be missing. but then again i was missing the cover for the bottom half of my bellhousing. snow, rain, rocks, would all get caught up in my flywheel n all that jazz. its bizarre how some previous owners treat their trucks.
Old Dec 9, 2009 | 10:29 AM
mpuvdd's Avatar
mpuvdd
Ya haha, my previous owner took all kinds of things off the truck. They took the rear bumper, the front bumper, all of the tie hooks on the bed, and balded the rear tires, leading up to running the brand new engine without oil I also noticed how they took out thier gun rack and cb, and they even had a dual oil filter setup on the thing. Ha, who knows what goes through peoples' heads.
