starting problem 2007 f150
Old Dec 6, 2009 | 10:32 AM
400case's Avatar
400case
good day eh
just bought a 2007 f150 with a 4.6 engine and it has about 57,000 kil on it.A couple of problems I have with it is that when I go to start it ,it sounds like the starter is under a load because it turns slow or I can here the solonod just click.Uusally what I have to do is try it a couple of times and then it just work normal.I would say this happens about 1 out of every 10 starts.It does not seem to make a difference wheather the engine is hot or cold.I tested the battery and it test ok.The other thing it did just yesterday was when i tried to start it after I just stopped it, it would not fire.It acted like it was flooded.It took about 1.5 minutes of steady cranking to start.Once started I turned it off and tryed again and everything worked ok.
any ideas?
thanks 400case
Penton97F150
1997 - 2003 F150
Jun 26, 2016 10:49 PM
gunner54
2004 - 2008 F150
Jun 13, 2015 06:49 AM
PEG
1997 - 2003 F150
Nov 5, 2014 08:11 PM
deputydog03
53
Nov 5, 2013 03:41 PM
trommy
1983 - 2012 Ranger & B-Series
19
Feb 24, 2011 09:08 AM
