2007 4.6L starting problem
Old Jun 13, 2015 | 06:49 AM
gunner54's Avatar
gunner54
got my truck (2007 XLT 4.6L V8) about 3 years ago, with a 6 month warranty (63,000). At that time it was not starting right. Took it back to dealer 4 times with no resolution. When starting it will turn over fine, I let it turn for about 4-5 sec and then let go of key. I repeat and sometimes it will start, most times not. On the third time it usually starts normally. I then get a heavy gas smell outside the vehicle. when I say normally I mean as in you turn the key and engine starts then you let go of key. Mine is you turn key engine starts but it seems like starter does not disengage and keeps trying too start truck. Its like it doesn't sense that the engine is running and cut the starter circuit. At idle it hits and misses sporadically. I have replaced spark plugs, boots, coils and MAF sensor. I am at wits end here. I love the truck I just want it to start right. Any help you can give would be greatly appreciated.
monsieurharper
2004 - 2008 F150
Dec 10, 2018 09:41 AM
neaners
Apr 15, 2015 10:01 AM
kencrystaljen
16
Jan 2, 2012 08:57 AM
ademonte5
Oct 7, 2009 07:53 PM
rustydog78
Dec 20, 2005 04:08 AM
