Manitoba / Saskatchewan Chapter Join Chapter, Leader: Fomoko1
Slowly getting things done
Old Dec 10, 2009 | 09:04 AM
preppypyro's Avatar
preppypyro
Ah yeah I getcha.
Old Dec 10, 2009 | 03:48 PM
Fullcrew7.3's Avatar
Fullcrew7.3
Just got back from the welder's about an hour ago. Got a few holes to drill and then start the install. Finally!!! Oh yeah, and the U-joints, but that's not a big deal.
Old Dec 10, 2009 | 11:48 PM
preppypyro's Avatar
preppypyro
Nice man nice, dont forget some install pics!
Old Dec 11, 2009 | 08:42 AM
Fullcrew7.3
You bet. I didn't take any yesterday, but I'll get some before anything looks too much different.
Old Dec 11, 2009 | 12:40 PM
Fomoko1's Avatar
Fomoko1
Your making good progress Dave.
Old Dec 11, 2009 | 07:40 PM
preppypyro's Avatar
preppypyro
You run into any huge problems at all yet Dave? (like something I should be watching out for when I do my swap?)
Old Dec 11, 2009 | 09:30 PM
Fomoko1's Avatar
Fomoko1
As always it`s money & time......
Old Dec 12, 2009 | 12:36 AM
Fullcrew7.3
I've managed to do things fairly cheaply. But the time thing........ I haven't actually spent a whole lot of time on it. Fitting it between other things. Oh yeah, finding the parts. That took time.
Old Dec 12, 2009 | 12:41 AM
Fullcrew7.3
What year and model are you swapping???
Old Dec 12, 2009 | 09:15 AM
LaredoF350's Avatar
LaredoF350
Sheldon was wondering about other things - the $$$ part is no problem!
Old Dec 12, 2009 | 11:26 AM
Fullcrew7.3
HA HA HA!!!! I wondered about that!
Old Dec 12, 2009 | 11:45 AM
preppypyro's Avatar
preppypyro
I actually found all my parts for really cheap, the money part was no issue. I dont even have 600 bucks in parts yet, and I JUST about have everything I need, minus a 5 speed tranny, if I want to go with a manual. Then there is the things like the rust proofing I dont have, a few of the larger bolts that I need, etc.
I have a 91 frame, and i have a 91 4 wheel drive. Basically I am going to take the complete suspension springs and all, and throw it onto the 2 wheel drive frame both front and rear. Along the way I plan on replacing anything that should be replaced such as bearings, bushings, seals, etc.
I have pondered a lift kit, and I may do that yet. Im also trying to find a reasonably priced 5 speed with a transfer case, so I can keep the truck a manual instead of going auto.
My big problem right now is lack of a warm place to work.
But yeah I thought i would ask to see if you ran into any actual problems when you were doing the swap. Are you putting some new parts in the front end while your doing it (tie rods, etc.?)
Old Dec 12, 2009 | 08:20 PM
  #28
Fullcrew7.3
F150? 250? 350?? Leaf? coil?? Details man, I need details!!!!
As for the lack of a warm place to work, I hear ya. Working in my unheated garage without a door and still a dirt floor. Not much fun, but at least it's out of the wind and snow.
Old Dec 14, 2009 | 02:25 PM
  #29
preppypyro's Avatar
preppypyro
f150 to an f150, nothing special at all, just stock to stock trucks. (with the exception that I may do a 6 inch lift)
Old Dec 15, 2009 | 08:27 AM
  #30
Fullcrew7.3
Does the 150 4x4 have leafs or springs in front? Not familiar with them. If the suspension is set up the same, it should be fairly straight forward. Obviously there will be the tranny swap to get the transfer case. But you already knew that.
