Im looking at buying a 91 f250 4x4 with a 5.0 and an e4od. When I start the truck I can feel It roll forward A little bit. I can put the trans In od or nuetral and It will drive and shift normally thru all 4 gears, no slipping and no noise no vibration, It shifts and acts perfectly normal. 1st and 2nd work fine as well. When I put it in reverse It rolls forward slightly then drops Into reverse, it will not actually back up, you can rev the engine to stall speed but no higher. Sometimes in park If you rev the engine It will actually over come the parking pawl and roll forward. Also when In park I can rev the engine to stall speed only. It only starts in p or n, and the reverse lights come on in R so Im assuming the mlps is adjusted properly and the manual protion is adjusted properly. I pulled codes and had 3 in total, ect shorted, egr flow insufficient, and 1 code for torque convertor clutch solenoid I believe It was 632. Im assuming the reving up to stall speed Is related to the tc code. The fluid level Is fine but is a little dark In color, I tried doing a search with no luck If there Is a post for this please direct me there. thanks
Thanks for the reply, After I submited this post i found another guy that had the same problem and his forward clutch and planetary was damaged. Your the third person thats told me thats whats wrong so safe to say its shot, again thanks for the reply.
