A while back I changed out my steering box in an attempt to remove the slack but it did not help much ( a little but not much ). Today I got the wife to wiggle the steering wheel while I watched all of the steering components and came up with this: The only place that I can detect any amount of play is where the steering shaft ends at the box. I'm now thinking that I bought a junk steering box. Now I know its not the best thing to adjust the screw on the box but would it be ok to experiment with or should I just bite the bullet and buy another one?
If you experiment an 1/8 turn goes a long way you don't want to get it too tight.
Have you jacked it up and checked for any slack in the bearings and balljoints.
I had one that I replaced everything on it and it turned out to be the rivits holding the crossmember to the frame, this was a 2wheel drive though.
Ok will do.
Yes, I've had it on a lift and inspected everything. The rag joint is new.
When I had the wife wiggle the steering wheel she only turned it enough to "bump each end of the slack", which was approx. 2" of play. As I watched the steering box you could easily see the play in the shaft but no sign of movement being transfered to the pitman arm.
