t stat
Old Dec 5, 2009 | 11:46 AM
milmo1's Avatar
milmo1
t stat
This should be fairly simple. My engine on the '99 Explorer 4.0 SOHC takes a while to heat up, and the temp gauge needle never gets much above the lower range on the marker. I'm sure it needs a T stat. It looks like there are 4 bolts for the housing. It also looks like I might have to pull the intake??
Any pointers? Its quite cold outside and I'd like to fool around as little as possible.
Old Dec 5, 2009 | 10:12 PM
scucci's Avatar
scucci
Spray some pb blaster on the thermostat cover bolts. Pull the manifold cover - four small bolts. Pull the intake hose. Pull the radiator hose. Remove the three bolts holding the thermostat housing cover and remove the thermostat and gasket. Reverse the procedure to install. Top off the coolant. Turn on the heater to max heat and start the engine. Run to full operating temperture to bleed the air out of the system. Shut off and top off the coolant.
Old Dec 6, 2009 | 07:27 AM
marragtop's Avatar
marragtop
I haven't done one on the SOHC, but on the OHV it helps to remove the serp belt. Doing so causes the tensioner to spring out of the way of the 3rd tstat bolt.
TMI
41
Apr 5, 2017 10:57 AM
jhweigel
17
Feb 7, 2015 04:07 PM
aba4430
Jun 12, 2011 06:26 PM
wycowboy
Nov 16, 2007 08:30 PM
muttsby
1997 - 2003 F150
Feb 26, 2004 01:08 PM
