Sponsored by: Real Truck
BATTERIES
Old Dec 6, 2009 | 10:57 AM
motown's Avatar
motown
Originally Posted by Pinky Demon
I use Deka batteries on my rig for plowing, which includes cold starts at 2:00 in the morning at 32 degrees or lower. No problems here.
I read on another forum that NAPA Batteries are now made by Deka. They seem to have a very good reputation.
Old Dec 6, 2009 | 11:22 AM
Chauncey's Avatar
Chauncey
Originally Posted by twall_SD250
i guess i cant go wrong with the stock one. i will have to see whats in there now because its the original battery its in my 01 with almost 180,000 miles on it...i would say i got good life out of it...it still cranks but its getting cold out and sluggish turning over in these cold jersey mornings..time to change i just hope whatever i get last along time...lets see i have a auto zone,pep boys, r&s strauss and advance auto all close by sould i goto one of the or my local costco
Let's see, 8 years and 180 K miles. Seems like a no brainer to me. I've never had a battery last that long.
Old Dec 6, 2009 | 11:38 AM
QwkTrip's Avatar
QwkTrip
Most cranking batteries are built equal. No need to spend a lot of money unless you need products that will last longer when exposed to severe vibration. CCA rating is a measure that gives you some idea of the ability of the battery to deliver high current for cranking the engine. The greater the CCA rating the more plates and thinner the plates. The greatest CCA ratings will be more susceptible to failure since the plates are not so strong and can be damaged more easily. The best compromise is usually a CCA rating in the middle of range of options, which is basically what Ford provided from the factory.
If you really need a boost in cranking speed then the Optima battery is a good choice. Instead of rectangular plates submerged in liquid, Optima uses a jelly-like sheet that is rolled into cylinders. This increases surface area and CCA rating, and also eliminates liquids from spilling and the battery can be oriented nearly any way you like. Optima batteries don't have as good a reserve capacity to power electrical loads without the engine running, but most people with special needs in this area opt for an extra set of deep cycle batteries anyway (like for RV's).
The red top is a cranking battery that will provide the best cold weather starting. The blue top is a deep cycle battery. The yellow to is apparently a hybrid of the two and based on the spec sheet doesn't seem to do either job well.
Old Dec 6, 2009 | 11:49 AM
QwkTrip's Avatar
QwkTrip
Ditto. I still have the original batteries in my 2000 7.3L. This year I'm finally seeing the engine struggleto crank and am expecting to replace the batteries before cold weather sets in. The engine had a bit of a hard start the other morning at mid 20F. Unfortunately, the costs might tally up because I think my Jeep Cherokee might also need a new battery if it gets as cold as last winter (-20F). But I hope it is doesn't get that cold so I can squeak out another year on the Cherokee battery.
Old Dec 6, 2009 | 12:04 PM
QwkTrip's Avatar
QwkTrip
Originally Posted by bayou barataria
Be careful that you do not overload your alternator though.
What do you mean by this? The alternator cannot be overloaded. It has a maximum output that it can deliver and that's all you get. Any electrical load beyond alternator capacity comes from the batteries. And the alternator can run at full output for the entire design life.
Old Dec 6, 2009 | 12:23 PM
87 F-150 I6's Avatar
87 F-150 I6
I would be wary of Optimas, made in mexico now, I bought mine right before they moved down there but ended up with one made in mexico and one in the US. I cant complain as they are a year old and still running, but well see how it goes. If I could do it all over again I would buy the cheapest 1000CC batteries and be done with it. I would add that MoterCraft batteries seem to last a long time.
Old Dec 6, 2009 | 07:36 PM
sandmn1010's Avatar
sandmn1010
Go motorcraft oem or interstate!!!, never go cheap on batteries
Old Dec 6, 2009 | 07:43 PM
bunklash's Avatar
bunklash
My last Ford truck was made in Mexico, no complaints!!
Old Dec 6, 2009 | 11:58 PM
QwkTrip's Avatar
QwkTrip
There is a difference between designed in Mexico, and assembled in Mexico. I don't think anybody here would buy a vehicle designed by a Mexican auto company.
Off topic a bit, but the American factory worker is a dying breed because it is being exported to lower cost labor- and that's not good. If you want to find the next center of power and wealth then you just need to look for who makes the most goods from raw materials. It's going to take much more then a "buy American" campaign to rebalance in our favor. I don't know what is the fix but I do know that people are going to have to be willing to sacrifice financially so that we can be competitive in a global economic environment.
Old Dec 7, 2009 | 12:14 AM
ALASKAN 13B's Avatar
ALASKAN 13B
I just replace mine with Interstate MTP-65. I own my own shop so they were about $65 per battery. Im a Interstate lover. I've never seen one go bad in less than 5 years and being in Alaska we beet everything up.
Old Dec 7, 2009 | 09:18 PM
mrsandog's Avatar
mrsandog
walmart batteries 2 year free replacement, and another year pro rated. cant beat them.
Old Dec 7, 2009 | 09:22 PM
bbender85's Avatar
bbender85
my red optima is dying after a year and a half.. fwiw.
ALF1999
32
Oct 16, 2012 07:44 PM
markh1
Feb 20, 2011 09:31 PM
turnrjr
Oct 6, 2009 07:11 PM
jmw132001
Nov 14, 2006 10:15 AM
jaw1959
Electrical Systems/Wiring
Mar 19, 2001 01:15 AM
