Hey everybody new here. I have a few questions.
I am new to diesels and I got a 93 F350 7.3 non turbo with 177k.The truck is in good shape and appears to be all origonal. It starts fine and runs really good. The ip and injectors look like they've never been touched.
So what Im wanting to know is what do I need to look out for in these trucks and what will the symptoms be if Im having pump or injector issues? On one hand Im glad it looks like it hasn't been messed with but on the other Im wondering if Im gonna have trouble soon.
welcome aboard. This place is amazing. There's so much information. You'll find that these guys will help you thru anything.
As far as your truck. I'd say if it aint broke don't fix it. But If you want to start to do preventative maintenance, the injectors, return lines and the glow plugs are pretty easy and affordable. Do a search for whatever you're thinking about doing. It's probably been covered.
I agree, if it starts and runs good, what more can you ask. Just keep a close eye on fluids and put some napa cool in the radiator. You will start to see little things you may want to do later on. Just keep reading the posts and you will learn something every day.
Welcome aboard
I agree and disagree here, does that make sense lol.
I hate to have to work on one when I have too but like to work on them at my leisure, does that make sense.
Just inspect anything periodically and replace what you think will be a problem on these batterycables come to mind as they will work marginally for a long time but when they fail it will always be at a bad time.
At 177,000 miles your ip and injectors will be worn now but may last a long time, these type of parts wear slow dropping mileage and performance so slow you don't notice it.
well i am one to tell you all about this. My truck has been through the ringer in the last 4 months, new engine, transfer case, gp's, wiring etc. I could pissibly have prevented my trnsfer case if i had seen the trans mount had a missing bolt and was torqued out of shape. I now do weekly belly to back, top to bottom on my creeper and led light(brightest i have seen!) There is nothing better than preventative maintenance. The injectors will need replacing and the pump is close probably. You could wait till you leak fuel in an injector and burn up a cylinder but why? the are about 20 bucks online for new ones. Dont go reman unless they are popped and matched. there is a guy on here but cant remember his name and he does this as well as warrants that they will work! Hit me up with concerns in a pm but never wait to ask, just get on here and know that you are literally accessing thousands of years of experience. Priceless!
supplemental coolant additive. It essentially provides a barrier to protect the metal from the destruction of the tiny bubbles that form on the outside of the cylinder walls. Rather than the metal walls being pitted or cavitated, the coolant additive is bubbled off. That is how in understand it anyway.
Thanks, I know it as DCA [diesel coolant additive].
DCA 4 is also what I use, but there are many names for it.
End result is the same for DCA 4 and Penn Cool formulations, they deposit a sacrifical layer on the inside of the cooling system.
The cavitation bubbles eat the sacrifical layer instead of the engine block.
There have been reports of the HOAT (Hybrid Organic Acid Technology) antifreeze causing gasket failure on older engines.
This is the same technology used in Ford Gold antifreeze which I ran in several of my reman engines.
Unfortunately none of them lasted long enough to figure out if it was a problem or not.
This is the product I am now using, carried at Tractor Supply and NAPA as well as other sources.
